i have now set myself a deadline, i booked the certification in for the 5th of december to get myself motovated to do get this truck finished
but ever since everything has turned to shit
went to put the front diff together and i both of my pinion nuts (inc the one for the rear)
so had to wast an hour or so to whip up some new ones but learnt my lesson and made them from high tensile
then i started work on the shackel reversal
sorry for the low rate pics but it actually does look quite good in person
then when i put the weight on this happened
you can also see there would have been little upward travel aswell so i had to put the extra leaf back in
bye bye ride comfort
then it was time to put the diff head in
and now i have noticed the castor angle is wrong and the front driveshaft is too short so the front housing will be coming back out and ill be making a new drive shaft
