Anyone have a winch near kumeu?
vinceparts
Re: Anyone have a winch near kumeu?
i had a problem with a shit load of my wiring the other week in my 2.8 diesel, althought that has a mech fuel pump, it turned out when i replaced the alternator brushes i had earthed out that main power (which also goes to numerous other high current things such as nearly your whole fuse box), therefore blowing one of the bigger 50amp fuses i think, one of the unboltable ones, but it wasnt blown where you couldnt actually see it , effen pain in the ass to find thats for sure, not sure if its all relevent to your case but may help
SP450andLE
I'd be keen on going on that safari.
But I'm too poor.
And the Lada may not be going reliably by then...
But I'm too poor.
vinceparts wrote:i had a problem with a shit load of my wiring the other week in my 2.8 diesel, althought that has a mech fuel pump, it turned out when i replaced the alternator brushes i had earthed out that main power (which also goes to numerous other high current things such as nearly your whole fuse box), therefore blowing one of the bigger 50amp fuses i think, one of the unboltable ones, but it wasnt blown where you couldnt actually see it , effen pain in the ass to find thats for sure, not sure if its all relevent to your case but may help
Yea im running a mech pump too, ive popped a few fuses so its jsut a matter of sorting through them all now.
027 MUD GEAR - (027 683 4327)
Check our facebook:
muddyhilux wrote:may i sugest running a wire from bat threw a fuse to inside cab threw a hidden switch then to pump,cheap form of imobilisation id say??
Was actually thinking of doing this,it seems like the easy option, as long as I dont knock the switch then it should be fine
Check our facebook:
uwshho wrote:muddyhilux wrote:may i sugest running a wire from bat threw a fuse to inside cab threw a hidden switch then to pump,cheap form of imobilisation id say??
You also need to run it to the key aswell.
Cheers Daniel
phraza
When, Where is this safari?
Could be keen... although Nov is a busy month for me...
Heading down to do the Tongariro crossing this weekend
2WD 06 Hilux... for now
