another terrano/safari project = terrari
Re: another terrano project.
What type of bonnet scoop are you planning on using Pete?
Ph 0212078472
Ph 0212078472
- passengerpete
kiwipete wrote:What type of bonnet scoop are you planning on using Pete?
i wont need one as its water to air so will have a radiator at front then pumped to inter cooler
passengerpete wrote:kiwipete wrote:What type of bonnet scoop are you planning on using Pete?
Oops
Ph 0212078472
Ph 0212078472
- passengerpete
been busy at work so things put on hold. a small up date the intercooler is mostly done but have no steel to make mounts to finish it. and nothing is open on a weekend that i know of. so i guess i have to buy 8m of steel just to cut 300mm of it lol.will sort that out this week also the water pump for the heat exchanger is not working so playing with at mo.have put it back to std until i get it all sorted.
have ordered some 3'' lift spring wont put em in just yet as will have a massive rake on it until front is sorted.
went for a wof and passed yay but he said that the drag-link is starting a bit sloppy so was trying to find the ball joints to fit it. but no one listed em... i guess it must be sold as a complete unit ?
wile i was under it i had a look around and found bent tie rods i did lol as this trucks runs on 30'' tyres and not been off road in my possession.
- passengerpete
have been starting to collect shit.... bits i think i might need in the future.
so have a open 4.8 diff from a wide body terrano that i want to some type of locker into not sure what to go with. a self locking type eg lock right or a air locking type.
also have brought a spear td27t out of a stolen bunt out Ute funny thing it was my old Ute only sold it to her two mounts ago bummer for her good for me. its had a good burn not sure what i could still use ? i only wanted it so i could mate a new gearbox to it so it could slip into my truck when i was ready.
also have got my grubby little paws on a nissan safari gq 5 speed so let the mating begin (in-cert porn music here lol) also got a terrano peddle box of trade me for $10.
having great fun playing with project it quite addictive this 4wd caper. can see a lot of wasted time in the shed in the future one day it might even go off road. the term 'maller' comes to mind like a rock crawler but only driving to the shops/mall lol.
- passengerpete
double up cant remove
- passengerpete
just on a side note the safari pto winch, whats need to get it going. im guessing the winch drum the pto shaft and something that goes into the gear box ? just curious thats all
- passengerpete
intercooler finished will put a pic up when its all painted up and looks prity, have added recaro seats too. best mod to date i think simple install too.
Last edited by passengerpete on Sat Apr 12, 2014 11:17 pm, edited 1 time in total.
what are the recaro's out of if u dont mind me asking?
- passengerpete
bighorn the 3.1 diesel one
passengerpete wrote:bighorn the 3.1 diesel one
are they a straight bolt in?
- passengerpete
keithal wrote:passengerpete wrote:bighorn the 3.1 diesel one
no not a straight bolt in used angle iron on one side and flat bar on the other, but no welding was needed still used std terrano seat runners if any thing seat feels about 10mm lower then std.
Last edited by passengerpete on Sat Apr 12, 2014 11:19 pm, edited 1 time in total.
- passengerpete
starting to get measurements together, to make a gq gearbox to td27t bell housing or an adaptor plate. so far it looks like a terrible idea because it not even remotely close. but im sure ill get it to work
I believe a td27t auto bellhousing, will bolt onto a td42 auto. Not sure what needs to be done with spigots thou. I know you've got manuels, but an old td27t auto bellhousing may make life easier.
- passengerpete
interesting will look in to that, thanks
- passengerpete
water to air intercooler all done im happy with the result.
got a mate to tig in a boss to mount the boost line.into the intake rummer, ya can see the spacer in this shot to
- passengerpete
also pulled the relief valve of old burnt out engine and welded a plate over it to stop it venting boost over 14psi.
- passengerpete
body lift is next just to give me more room for gearbox and stop the intercooler from rubbing on bonnet.
Nice
What boost you planning?
Keep it up.
Keep it up.
- crazyclark31
very neat and tidy. nice. almost looks factory
Looks good
Might just have to get rid of that u-r-a-bus sticker from cooler
- passengerpete
slide wrote:Looks good![]()
lol, all sorted my flat mate is a sign writer will turn the Subaru into a Nissan so it will look factory.
- passengerpete
sibainmud wrote:Nice
Keep it up.
thanks not sure what boost ill run just yet. at mo im running 12psi
- passengerpete
so started the body lift to day got mostly done just a few wee things to do with hand brake cables ect
i also pulled of the running board off before they get bent all so found so jap coins and chewing gum look funny i get a pic latter
- passengerpete
some stuff i found when i pulled out carpet to do body lift. im rich lol
Last edited by passengerpete on Sun Apr 13, 2014 9:13 am, edited 2 times in total.
- passengerpete
td27t backing plate inside the td42 bell housing
- passengerpete
if any one has a td27 manual gearbox out of there truck at the mo could you please measure how far the input sticks out past the bell housing edge. the easiest way would be to put a straight across the face of bell-housing then measure the protruding end of input shaft thanks
- passengerpete
finished off body lift, raised front bumper but wil leave back one low so can mount some hooks above it,
- passengerpete
found some spot lights on tm so put em on and run the wires
- passengerpete
put in new springs its a bit highter then i was expecting
