Gidday all,
I have an LN106 double cab that I want to lift 4 inches in suspension and 2 in body so I can run 35s.
I have diff gears and everything sorted (will be running 5.29s) and ARB lockers front and rear.
Was just wondering what the best suggestions for lift are. I want everything to run the way its should so it will be done right e.g castor wedges, dropped drag link etc
If anybody has any suggestions or knows of any decent kits out there it would be greatly appreciated.
LN106 Lift Advice
uptomynutsinruts
Re: LN106 Lift Advice
Could do RUF coons in the back, depending on what you want to do, or do a coil conversion for the front.
- Steve_t647
What do you want from the vehicle?
Ride quality and handling? Grind everything off the diff get mounts and arms made and fit Coilovers. More time consuming but cheaper option swap prado running gear under the Hilux taking as many mounts off the chassis as poss.
OffRoad Hack Hunting truck? rears up front but it is not a cheap option, you need surf power steering box, new steering shaft, crossover steering conversion, new longer front drive shaft and if like me a track rod over the rear diff.
Falcon springs are very long and soft in two trucks I know of coil "helpers" were needed on each side to stop bottoming out and both have trac rods to minimize climbing issues.
Remember you are going to need to get it certified so think carefully I stuck with leaf springs, crossover steering and track rod with good drivability but now and moving to coilover shocks to get away from them so I will go through cert twice.
There is no one answer that is right for all I am also going wider (Cruiser or Patrol diffs) and lower (trimming the guards) to make things fit, mounting the shocks higher blah blah blah then I am going to drive it around supermarket carparks and past schools to scare the pants off single mums.
P.S. That last comment is not intended to offend the PC Police it is intended to be funny.
you wanna move your diff forward to run 35's btw, rear leaves up front with crossover steering conversion
uptomynutsinruts
cheers guys,
just messaged tom from tomsoffroadandcustoms to see about getting coils and full cage, yea if i wasnt doing that id be going coons in the back with RUF and hi steer probably, ill see what tom comes up with.
- Steve_t647
uptomynutsinruts wrote:cheers guys,
OK if you are going for coils you will get a way better (more comefortable) result but there is a cost to it. Looking at a coil conversion the fastest and easiest method would be to grab a goil surf rear end and the mounts (chop the rear part of the frame out) and you also get more width if you chose the right surf
For the front find a wrecked prado and again chop the frame out taking the springs mounts and all, you gain a high pinion diff from the prado and if you find the IFS Surf front hubs and space the brake disk back you get the same (or so close) width as the back.
This is all 8" running gear with the ratio's you previously had available to you, if you want bigger diffs then the landcruiser or Safari is an option. Have a chat to Rick at 4wd accessories, he is in a new workshop and has done most of these conversions before and delt with the problems others (who will remain nameless) conversions have had.
He may even sell you the laser cut and folded brackets you need if he is not doing the work this will give you a head start
Cheers Steve
uptomynutsinruts
Hi steve,
Thanks heaps for that, I'll give rick a call and see what he says, after a more comfortable ride, the old leaf springs are just an all round crap ride haha and after more flex
I could probably pick up a surf rear end from a guy I know for quite cheap. What width am I looking for for the wider one?
Cheers, Michael
Cheers, Michael
uptomynutsinruts wrote:Hi steve,
Thanks heaps for that, I'll give rick a call and see what he says, after a more comfortable ride, the old leaf springs are just an all round crap ride haha and after more flex![]()
Cheers, Michael
Woulda been cheaper to sas your surf, and hiluxs are meant to be rough lol
uptomynutsinruts
Yea I know haha but always wanted a double cab. When are you going to sell the Terrano and come over to the darkside? haha
uptomynutsinruts wrote:Yea I know haha but always wanted a double cab. When are you going to sell the Terrano and come over to the darkside? haha
When someone buys it for dece money. And im not sure wether i want a cefiro or a lux really. could keep the tbag and get a ceffy for best of both worlds
- BeamedSurf
- Bush Crasher
Come over to the beam axle side mate, im not sure what its like yet cos mine doesnt go haha
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
