Cryogenic Freezing in ChCh... Stronger CV's, Gears etc
brakes-shocks-lockers-etc
kbjj
Post by kbjj »
Dropped my axels, cvs and hub gears (13kg) off earlier this week to get cryogenically frozen. The Gearbox Company, 98 Falsgrave Street does this for $20 per kilogram. Alot of people speak highly of this treatment for gearbox components to engine componets etc. Is said that it can strengthen up to 3 times original. Basically it aligns the molecular structure of the material.
The reason I'm pushing this, is the moment they have 50kg to be treated, the sooner I get my stuff back. Not to badly priced either.
Twodiffs
Re: Cryogenic Freezing in ChCh
Post by Twodiffs »
I didn't know that :shock: so I could take my spare cv's and axles in and get them done and they would be stronger?
At the mo the cv's are pre packed with grease so they would have to be cleaned first correct?
mud_slinger
Post by mud_slinger »
cv specialists also do this i believe
needs more curry
0272593533
kbjj
Post by kbjj »
Twodiffs wrote:I didn't know that :shock: so I could take my spare cv's and axles in and get them done and they would be stronger?
Yep, everything I've read about it seems good in theory and testing.
http://www.metalravne.com/selector/heat_treatment/cryogenic_treatment.html Just an example, plenty more info out there.
Clean the cv's and dismantle them, which will elimanate the risk of loss of clearance during freezing, which I guess may cause stress. Parts can be left in plastic bags to keep them together.
I was led to believe The Gearbox Company is the only South Island outfit doing this.
Some test results http://www.nwcryo.com/motorsports_gears.html
kbjj
Re: Cryogenic Freezing in ChCh... Stronger CV's, Gears etc
Post by kbjj »
Bump... see 1st post
ClassicCruiserSpares
You should do you transfer case at the same time or your spare one?, Because if you do all the front diff then your transfer mite go again :D
And I am thinking about doing mine but I just dont have time at the moment.
niblik
Post by niblik »
ditto on vomitron's front...
