Hey guys,
Just after the sizes for the body block bolts all round, are they all the same or nah?
Caleb
Bolt size for Ln130 surf body blocks
027 MUD GEAR - (027 683 4327)
Check our facebook:
Re: Bolt size for Ln130 surf body blocks
Same diametre man,just make sure the tensile strength is 8.8 or more
I havnt pulled any of the bolts out yet, was just after the size so I could grab some from msl on my lunch break.
Check our facebook:
vinceparts
8.8 grade needs to be used for all bolts as well as nyloc's. the front 2 are m10 x 120mm, middle 4 are m10 x 130mm and the back 4 are m10 x 160mm. That is for a 50mm lift
Sam
Sam
Definitely would only use high tensile bolts, thanks for the info guys
Caleb
Caleb
Check our facebook:
