fixed diesel leak from injector return line.
two, hit a commodore with the ute
pulled the grille and bumper a hammer and wooden block straightened the bent steel supports a few tec screws all back together like it was before
coxsy wrote:James is 21 today
uwshho wrote:Went out to hampton downs with sibainmud, lincooln, drurban, hiluxdan and luke (sorry dont know your ore name) met up with Gary, had a chat about mudfest and went and tested out the place.
Its shaping up to be a decent event, looking forward to it.
Didnt get any photos as my cam spat the dummy.
Caleb
uwshho wrote:Went out to hampton downs with sibainmud, lincooln, drurban, hiluxdan and LUKE (sorry dont know your ore name) met up with Gary, had a chat about mudfest and went and tested out the place.
Caleb
mfrsr
Post subject: Re: 26th 27th
cleaned Surf. lot of oil on the rear diff.... not a bad effort, i only lifted it two weeks ago and its already eaten the pinion seal. And i've only done like 15km.
mfrsr wrote:cleaned Surf. lot of oil on the rear diff.... not a bad effort, i only lifted it two weeks ago and its already eaten the pinion seal. And i've only done like 15km.
tomsoffroad wrote: Lifting it shouldn't affect pinion seals![]()
