excessive intake noise?
tuk
Post by tuk »
Hi
I have a 2.8d turbo and i snapped the timing belt while idling along due to mud getting in behind the cover, I took the chance and put a new belt in. fires up 1st time with no smoke, runs good but its hugly noisy out the snorkel, especially at high revs. Does this sound like the timing out or just some internal damage. Still goes hard but maybe slightly down on power, had a afternoon run out at the river and never missed a beat.
any ideas out there?
SMOKEY
Re: excessive intake noise?
Post by SMOKEY »
If the noise wasn't there before I would say bent valves, damaged camshaft pedestals or cam timing out. FITZY.
tuk
Post by tuk »
definitly wasnt this bad before, i thought if it was internal damage the power would be well down, still spun the wheels in the mud, crossed rivers and revved right out with no problems. a big loud tractor springs to mind, but all the noise is out the snorkel?
Smurf
Post by Smurf »
tuk wrote:definitly wasnt this bad before, i thought if it was internal damage the power would be well down, still spun the wheels in the mud, crossed rivers and revved right out with no problems. a big loud tractor springs to mind, but all the noise is out the snorkel?
You will be a tooth out on your timing belt, been there and done that, mine sounded like a tractor too.
tuk
Post by tuk »
cheers for that "smurf" will re-do the belt
tuk
Post by tuk »
Reset the timing belt as per the manual, everything lines up perfect on the diesel pump, crank, and cam. aswell as all the lines on the belt. But still a tractor noise? is it definitly a timing issue?
pruggerdore
Post by pruggerdore »
Im thinking valve train damage. i would do a compression test but diesel compression testers are expensive. Is the top end noisier at all. as in big tappet clearance from bent valves not fully closing. maybe take tappet cover off and check clearances. should be able to do that as you have the book. tho if valves are not full closeing it must be very minor as it is still running ok
you do have the air filter in the box. that would do it, lol
tuk
Post by tuk »
running a snorkel off the turbo witha pod filter on the end, sounds normal under idle but just a bit deeper, once you rev it up it gets louder and louder untill its screaming when it gets to the redline, had the snorkel come out just above the passenger side roll cage but way to noisy to drive without earmuffs... theres no missing or exhaust smoke or rough idling, starts first click aswell?.
Only a bush truck so will proberally just drive it like it is... did 20-30kms last week at the river and didnt miss a beat (had to extend the air intake out the back of the truck tho)
vinceparts
Post by vinceparts »
my 2.8 n/a hilux after a 3 inch stainless snorkel off of the factory airbox gives this horrid drone with the passengers window open, its got this sweet spot at 3000rpm which it effen annoying on deceleration, reading this makes me wonder if mine is normal or not?
Cass
Post by Cass »
n/a diesels with a pod filter are normal to be loud and droney
vinceparts
vinceparts wrote:my 2.8 n/a hilux after a 3 inch stainless snorkel off of the factory airbox gives this horrid drone with the passengers window open, its got this sweet spot at 3000rpm which it effen annoying on deceleration, reading this makes me wonder if mine is normal or not?
tuk
Post by tuk »
had a pod on mine for over a year and it wasnt that loud, only since iv snapped / changed the timing belt. unbearable if u are sitting next to it.
likemagic
Post by likemagic »
check if your engine is listed here
http://www.aa1car.com/library/timing_be ... ngines.htm
interference means if the cam belt breaks the piston meets the valve for a not too gentle introduction
Maurice
KZN185, 1KZTE running needing birthday
tuk
Post by tuk »
hi, through some investigations i was told that sometimes if the tapetts are too tight it can cause excessive noise out the intake, but not the cause of my problem.
tuk
Post by tuk »
the cause of my problem maybe one of the valves isnt seating properally, not enough to make it miss but will burn out the valve. so my option is to strip it down and fix but could enter into the mid hundreds by the time its finished. Only a mud / river truck so goina beat it till it dies....
