master cyl change ideas please
aroma
Post by aroma »
looking at changing my factory master cyl to a vac assisted one mounted on the firewall not bolted to the chassis :?
current one has plunger of 1- 1/8 dia by 1-1/2 inch travel ,one outlet going to drums all round
what would fit ,40 series crusier or ?????
would need the master cyl and pedal ,etc
would I need to cert this change ??
Warren
Re: master cyl change ideas please
just stick a later model vac 40 series one in, they are twin outlet so you'd need to do a wee bit of plumbing
aroma
Post by aroma »
wernt they disc on the front? and could I plug one outlet, two outlets let would be a little too much plumbing as replace pipes while rebuilding it :oops:
Return to “Tool Shed”
