would these fit 91 Surf on std suspension
brianr70
Post by brianr70 »
would someone be able to advise if these would fit 91 surf on std suspension :?: :shock:
http://www.trademe.co.nz/Trade-Me-Motor ... 533884.htm
padero
Post by padero »
yeh shouldnt see why not..
ad
wopass
;-p
Post by wopass »
yes.
if they dont fit, your suspension has sagged :wink:
Macca
Post by Macca »
Should fit ok. May rub in front on full artic and lock but thats no biggie. normally just rubbing on sway bar. If they rub excessivly you can crank the front suspension up but the back requires more work.
So YES they should fit if suspension is standard as surfs had a 31inch factory option and these are only a little bit taller
Return to “Tyres”
