Lj78 diff oil
Landyota
Lj78 diff oil
Post by Landyota »
Can someone please suggest to me the 'best' oil to use in the standard rear electric locking lj78 diff. I have seen various hints that you need to be careful with the locking diff but nobody has actual said - 'use this' - not that I have seen or can find anyway!
Thanks
Re: Lj78 diff oil
lsd oil ... stuff from bnt seems ok
IcedJohnno
Trailer Trash
Re: Lj78 diff oil
Post by IcedJohnno »
I use this oil;
http://www.redlineoil.com/product.aspx?pid=44&pcid=8 available from BNT.
I use it in both diffs of my KZJ-71 Prado. The rear like yours is the E-locker and the front end has a 4 pinion rear style LockRight. It will help with the high shock loadings that get applied when snatch towing or those applied to the 1/2 shaft splines when cross axle-ing with wheels spinning and then taking load.
LSD compatible oils are for the clutch type arrangements of a limited Slip diff. Entirely different from an e-locker.
pruggerdore
Re: Lj78 diff oil
Post by pruggerdore »
that red line looks good. going to go to that next time. running lockrite in back and elocker in the front.
Landyota
Re: Lj78 diff oil
Post by Landyota »
Thanks guys, looks like I'm off to BNT tomorrow for some redline oil!
Return to “Toyota”
