Hi guy i have almost payed off my surf so now im looking at making it alittle nicer for 4wdin..
i had a talk to the old man and he almost put me off getting some big and better tyres and raising it...
just wondering the pro's and con's of rasing a 89 hilux surf two door??
i realise that this has most likely already been posted but im to lazy to search round here all day. cheers Tom.
pro's and con's of raising a surf.
goosebayhunter
- Driver/Navigator
Re: pro's and con's of raising a surf.
To be honest, with an attitude like that, your not going to get very far around here. It has be covered alot, and shouldnt take much searching to find, atleast not all day.
Cheers Daniel
Cheers Daniel
X2, if you're too lazy to try and look yourself, why should others help you?
goosebayhunter
- Driver/Navigator
yea that seems resonable ill have alook..
goosebayhunter
- Driver/Navigator
hi guys sorry for the lazy smartarse comment earyler..
just wondering if a beam axle would be the way to go to raise the truck and get better all over suspension etc. any help would be greatly helpful cheers.
goosebayhunter wrote:just wondering if a beam axle would be the way to go to raise the truck and get better all over suspension etc. any help would be greatly helpful cheers.
Yup
A solid axle would solve alot of problems, but its not a cheap exercise. You can lift an ifs truck 2 inchs without any major dramas, allthough the front diffs are made off glass, and auto locker fixes this problem. But creates another. Its all depends on what type of driving you want to do, and how much you want to spend.
33's will fit on with 2 inch spring lift, and some slight guard trimming.
Cheers Daniel
Cheers Daniel
If you do a body lift you will be able to fit 33's under without any problems. I did for a few years. I like having a surf as although they are slightly underpowered I can get a good amount of lift and run big tyres and still be able to take it into a carpark. Its my daily drive and therefore important. A well setup surf can go just as far as other trucks.
Sam
Sam
