Wanted: Patrol GQ PTO Output shaft Seal info
Hi folks, my PTO box is leaking gearbox oil onto the extractors, really stinking up the truck... Has anyone replaced theirs who remembers the output shaft seal specs or part numbers? Kinda dark at the mo to go pulling it apart, rather get the bits then just throw them in if I can... cheers, Terry
Re: Wanted: Patrol GQ PTO Output shaft Seal info
Hi Mate will get you the seal numbers tomorrow ,i have just rebuilt all my winches ,got the seals from bearing supplies up here in Auck .were only about $6-8 each
awesome
cheers, Terry
Hi Mate the numbers on seal are AE1351E NOK.
sweet - Seal Imports translated that into a 25mm x 47mm x 6.35 seal, I've gone with their closest, a 25 x 47 x 7mm, in viton (hopefully a bit more temperature resistant than the old one - the extractors are about 20mm away...) I'll see how it fits tomorrow - worse case scenario I have to take the old one in, but this gives me an excellent chance of a same-day repair.
thanks heaps, Terry
thanks heaps, Terry
Thats the same ones that i got from bearing supplies they work fine.
Steve
Steve
