looking at buying a 96 3.2 with 220km on it
what things do i need to look out for and check first.
also what are they like on diesel.
info on terrano wanted
Re: info on terrano wanted
seat and seatbelt mounts in rear rust ( not sure what years)
If it has and its been fixed I think it needs a cert if its on the road
someone else on here should be able clarify that tho
rolla4wd wrote:seat and seatbelt mounts in rear rust ( not sure what years)
It's a R50, not applicable.
Those ones have been known the have trans issues that cause over-drive to be dopey and the torque converter won't go into lock up mode.
Trailing arm bushes can get worn causing the arse end to wobble around a bit. Apart from that mostly all good.
airflow meaters and diesel pumps intake hose splits auto trans is beater than d21 dash clusters pack up good for RUC
other wise ok dont get ZD30 hand grenade
