doesn't matter if a BOV opened under water. boost blows water out. if worried about it plumb it back to air cleaner.
but the air under boost is stil going into cylinders and not stopping causing compressor stall.the only time air would stop going thru the cylinders is wen the engine is shut off.
your forgetting pressure pushes in ALL directions. so you have air pushing towards the motor but its also pushing back against the turbo compressor. theres no one way valve or seal (like some superchargers), the only thing stopping it going back through the turbo is the turbo is throwing air out of it faster then it goes back in. but when the turbo can't throw air out, cause its got no exhaust pushing it, the boost wants to go back through the turbo.
factory diesels don't have bov because its not a major problem for them. a throttle butterfly causes a bigger problem thats worth them spending $$ on it. with standard diesel the problem is not big enough to spend the $$$.
mind you the navara ZD30 diesel runs a butterfly, 15psi+ boost and is also known for snapping compressor wheels. but nissan are to cheap to even fit an intercooler.
these days they use turbo back pressure for the egr system instead of intake butterflies.
Diesel engines running high boost pressures are designed and engineered from the get go to run under those conditions. Wee car engines aren't...
disagree with that.
tons of people here are running higher boost than the diesel engines where ever designed for, a lot of them pushing stock turbo's to the limit .........and some well past it
especially when fitting small turbo's to gain low down boost.
tallsam66 wrote:The best thing you can do to get more out of ya diesel is to help it breathe so big air in & big air out...then you will get complete burning of the fuel & get max bang for ya fuel.
when a BOV operates there is no (or minimal) fuel going in so the air does nothing anyway.
no need for dyno charts as BOV makes no difference to power what so ever.
