LN60 surf build
LN60 surf build
hey people, just bought my second surf a couple of days ago and im dead keen to get stuck into it!
its a bog standard 2lt 1985 hilux surf.
first thing to do was put a better audio system into it (scored it out of my last surf before i sold it)
second step is to sort the suspension out before it goes for a wof.
tim (hosehustler) supplied me a pair of ln106 front leaf springs as the origionals are sagged beyond help.
the back end has had a shunt at some stage, so i got stuck into replacing the rear shackles and shackle bushes today. it drives so much better...
future mods are-
better wheels and tyres
fit the snorkel
mild lift
lsd
and possibly a winch and solid front bumper (if i can afford it)
i'll keep the build updated as much as i can as i do it
future mods are-
fit the snorkel
mild lift
lsd
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
Re: LN60 surf build
heres some pics...
- Attachments
- Picture010.jpeg (90.4 KiB) Viewed 6770 times
- Picture008.jpeg (51.08 KiB) Viewed 6770 times
- Picture007.jpeg (88.43 KiB) Viewed 6770 times
- Picture006.jpeg (70.63 KiB) Viewed 6770 times
- niblik
- Sausage Shack
Re: LN60 surf build
welcome aboard chap.. good list ya got.. keep it simple and learn to drive the thing.. remember, she's a 2lt, not a performance monster.. if ya do that she'll do ya right..
hope we dont get a wobble...
Re: LN60 surf build
I would recommend you if are gettin a LSD, get a spacer machined up and fitted into the clutch pack to tighten it up,, std, old (worn) LSD's are pretty much useless
Got a Daihatsu Something, hasn't got a Daihatsu engine.... or diffs.... and it doesn't have windows.... or doors.... but its got tyres....
Re: LN60 surf build
haha you can just spot the axle stands under there for extra (wobble) protection...
my last hilux had a 1kzt conversion, so this one is much slower, but goes very well compared to other 2.4's ive driven.
looks like its been well looked after through its life
Re: LN60 surf build
Fakey wrote:You mean the stands right up the front?
yeah those ones! bad photo angle.... i'm not that silly
Re: LN60 surf build
ok so the left rear eye mount is a little bit dog looking.
obviously was welded back on after the shunt that wrecked the shackles.
what do you guys reckon? tidy up and reweld, or put a replacement one on?
will be going to tomsoffroad in the weekend for a reweld if its going to be fine.
i cant seem to add the picture or add a link at all. odd...
heres a link
http://s1119.photobucket.com/albums/k62 ... ure002.jpg
heres a link
Re: LN60 surf build
righteo, put another fuel level sender in tonight.
also whipped in some new shocks all around for a bit of 'comfort'
these will be sold as soon as i get new lifted springs all around.
ill put some raw nitro shocks on with the new springs.
next up is sorting out the wheels and tyres.
i can see the $ dropping
- crazyclark31
Re: LN60 surf build
that eye mount does look bit dodgy. I'd be taking it to tom to get his opinion.
Re: LN60 surf build
fair call. i have a 4x4 trip up around benmore tommorrow. i'll whip it over to him after that
Re: LN60 surf build
ok, yesterday was productive.
the surf now has a cool new snorkel.
all stainless steel, seamless with a brushed finish.
i'll whip the pics up later tonight!
- tomsoffroad
- Flopsie
Re: LN60 surf build
Sounds choice. Waiting patiently
Re: LN60 surf build
here ya go
- Attachments
- no seams to be found here!
- DSCN1662.jpeg (47.93 KiB) Viewed 6304 times
- nice and simple joins for less then 10 bucks ;)
- DSCN1661.jpeg (46.37 KiB) Viewed 6304 times
- the only shiney part on the truck
- DSCN1663.jpeg (87.03 KiB) Viewed 6304 times
- tomsoffroad
- Flopsie
Re: LN60 surf build
Very very nice
Re: LN60 surf build
tomsoffroad wrote:Very very nice
cheers!
he build kiwipetes snorkel as well.
his own snorkel is the spanky one though. all alluminium and even fabbed his own hat up.
Re: LN60 surf build
kool looking surf you got there. not to often you find them that tidy.
mine looks like a golf ball compared to your one
wayfastwhitee
Re: LN60 surf build
Snorkle looks awesome, where'd you get that bent up?
- niblik
- Sausage Shack
Re: LN60 surf build
very tidy wee snorkel alright.. just be careful nudgin past tree's or banks as it could cause (depending on how its mounted) trouble for ya windscreen or snorkel itself..
Re: LN60 surf build
surf10 wrote:kool looking surf you got there. not to often you find them that tidy.
cheers! its reasonably striaght for its age. little bits of cancer starting but nothing major.
wayfastwhitee wrote:Snorkle looks awesome, where'd you get that bent up?
it ain't bent up
shes made of mandrel bends and straights.
about 7 tigged joints i think, but they got ground down and the whole thing had a brushed finish polished in. looks seamless now
Re: LN60 surf build
okey dokey, took it for a 4x4 in the weekend and managed to blow oil all over the underside of the truck. front crank seal was leaking quite a bit, so i pulled it to bits and put a new one in. i was putting it all back together and spotted the sump gasket was also falling out (explains even more as to why theres so much oil). what the hell couldve caused that!!!!? also found greasy slime in the cooling system. i hope like hell the engines not screwed!
it apparently had the head gasket done in it, and i can see newish gaskets all over the place.
should i really bother with this motor? i cant really afford to buy a good 2.8 to jam into it right now. i can get the necessary parts to rebuild a knackered one at cost price through work.
what should i do?????
Re: LN60 surf build
put a new crank seal in. and when i checked the timing, the cambelt snapped like a match stick. barely any resistance whatsoever. i can only put it down to possible oil contamination. went the whole slog and ended up replacing everything while i was in there. lets hope the engine holds together till i find another motor...
Re: LN60 surf build
ok, day off today so i tidied up residual oil left from the leaking sump gasket.
got it right on the second new gasket
they are tricky things to get the right tension on the bolts too! a little over tight and it splays out the gasket ends and starts leaking.
im fitting up the cb radio to it now. many people still using them offroad?
