Giving the truck a birthday
samewan
Post by samewan »
so im giving my truck a birthday to get a wof.....What im only out buy 2 months.
so at the moment its at uni wield geting a 2.5 from the flexi, got some engine cleaner, new oil and just going to pick up the rear diff and put that in over the next couple days .I did a full coolent flush yesterday and found the thermosat is buggerd so got a new one of them too.ohh and some degrease to give the engine abit of a tidy up.
so to the main question any thing ive missed or should be doing?
badnuz
Re: Giving the truck a birthday
Post by badnuz »
all new filters- Air/oil/fuel :)
samewan
Post by samewan »
a ha new i was forgetting something.
Brown Smurf
Post by Brown Smurf »
Maybe a going over with the grease gun on the underside before your wof.
Karl
if your checking stuff over for a wof its mostly mechanical shit, brakes (well we dont have to worry about those coz you already stuck new disc pads in the other day :mrgreen: ) but you might want to pull the drums off the back and clean all the mud and shit out, inspect the shoes, free up the adjusters and adjust them up, check the steel brakelines for rust and the flexible hoses for cuts, perishing or buldges, if your handbrakes on the back of the transfercase there should be an adjuster cam to tweake that up, check all your steering balljoints and suspension bushes for play, check all your lights and electrics are working etc etc..... sometimes its just easier to take it in for a wof inspection to get the fail sheet and just do all the shit on the list or you endup doing a whole pile of stuff they dont ask you to do :x
if your servicing the truck all of the above and check/replace the fluids, theres probably 100 bucks worth of diff and gearbox oil so you probably just want to check that its good clean oil before you go changing it for the sake of it, engine oil and filter, air filter, fuel filter, grease all the chassis points, if your soild front axle pull down the swivel housings and check/repack the CV's and wheel bearings etc etc :mrgreen:
Roenut
Post by Roenut »
amen to doing all the filters, grease all the driveshaft nipples etc even jack the front up and check the front wheel bearings.
i'd even run a good injector cleaner through it to clear it out
if anyone needs bits and pieces, bowl into BNT in hornby and i'll sort out a set discount for ORE members.
Rodney
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
ClassicCruiserSpares
Roenut wrote:if anyone needs bits and pieces, bowl into BNT in hornby and i'll sort out a set discount for ORE members.
Rodney
Good to know, Ill be in for sure. :D
Roenut
Post by Roenut »
Rodney
all good, just ask for me and mention ore and i'll be more then happy
samewan
Post by samewan »
just down the road choice will see ya down there some time... 8)
Roenut
Post by Roenut »
samewan wrote:just down the road choice will see ya down there some time... 8)
sweet as!
samewan
Post by samewan »
holy crap getting cvs out that are shit angles out is hard ...it the end came off and threw grease at me.
Return to “Tool Shed”
