i have a ln130 surf that i have just put a 1uz into it and my mate has a d/cab ute with a 1uz in it also
we both using same rubber engine mounts
mate has done about 2000ks since he fitted engine and he has ripped both of his mounts clean off where the stud plate is glued to rubber (see attached photo below has ripped where red arrow is)
because i using same mounts as him i dont want this to happen to me so this is where u guys come in:
is there a stronger solution using different materials?
have heard that having a crush tube in centre of mount is clased as being solid mounted which is fine but then have to solid mount gearbox too which means nosie transfer - not want i really want?
due to the whole engine setup being done new mounts need to be same size (currently 50mm high) so factory rubbers dont fit as 80mm high and 1 stud comes out on angle
any ideas why they broke? wat would you use?
