fj40 brake issues
2.f
fj40 brake issues
Post by 2.f »
hey
my old fj40 brake booster and master where buggered,so i replaced the system with a 2nd hand fj40 booster and 1994 hilux master clyinder,the brakes where really hard and the truck would hardly stop,so today in replaced the booster with a 1994 hilux one and now the pedal is soft.
is this air in my lines
or
not enough vacuum for the booster
SP450andLE
Re: fj40 brake issues
Post by SP450andLE »
Do the brakes still work, even though the pedal is soft?
2.f
Post by 2.f »
i kant get it out of the garage atm to test it properly but i put a jack under the back diff n pushed the pedal and the stoped instantly
bleeding them is a pain, done a few nights with my sons 40
Roenut
Post by Roenut »
have a look at both cylinder bore sizes to see if theyr different. bigger will put more pressure on brake components, smaller wont have enough omph to get everything working hard enough.
dont quote me on it, just speaking from experience...
Less Traction More Action!
previous vehicles - commodores, bmws, subarus, 1kz surf, d21 terrano.
ln60 surf, current - kzn130 surf
ClassicCruiserSpares
Why not put a factory booster and master cylinder back on, problem solved? If I remember right you have discs on the front? so bleeding would be very easy.
2.f
Post by 2.f »
i would of but i got given the 94 hilux one and thought it would work,
yup 60 series front end
you got any,if so how much?
check this place out for fuel injection system for fj40's
http://www.affordable-fuel-injection.co ... rt/?p=home
Fakey
Post by Fakey »
The pedal would've been hard with the other booster cos it prob had a vacuum leak.
What were the brakes like before you fitted the hilux parts?
How's your rear drum brake adjustment? Check that then rebleec the system, shouldn't be too hard to bleed at all..
Didn't barbie drive a jeep??
coxsy wrote:check this place out for fuel injection system for fj40's
How's a fuel injection system going to fix his brake problems? :roll:
not just thought you 40 guys will read this thread an find it, and once its here , can be found again :roll:
2.f
Post by 2.f »
the brakes before the hilux parts where crap as the orginal booster and master clyinder where buggered.could it just be that theres stil air in the master clyinder?
vinceparts
Post by vinceparts »
well after day at woodhill my brakes were fine when we left ( standard ln106 hilux brakes) as the day went by my brakes got worse and worse till my pdal would bottom out and id barely be slowing down, so i started on rear first and replaced new shoes and new slaves cylinders in the back nd got half my pedal back (thi is aafter i re bled everything) so im guessing once ive rebuilt calipers and new discs and pads my brakes hsould in theory be better than they were
2.f
Post by 2.f »
i finally got to drive the fawty,and the brakes are either on or off,and you have to press the pedal along way down before anything happens.it fells like most of thr pressure is going to the front (discs)
Pedro
Post by Pedro »
Roenut wrote:have a look at both cylinder bore sizes to see if theyr different. bigger will put more pressure on brake components, smaller wont have enough omph to get everything working hard enough.
close but wrong,
smaller master= more travel, softer pedal, less fluid displaced
bigger master=less travel, harder pedal, more fluid displaced
pedro
2.f
Post by 2.f »
so should i just go back to a fj40 brake booster and clydener
2.f wrote:so should i just go back to a fj40 brake booster and clydener
Yes :D
Return to “Toyota”
