Does anyone know how to tell the difference between a early 18 ACR alternator and the 25 ACR?
Mudhog has it's original alternator and I have one that is larger in size off a parts truck I have and was wondering if it would work better to charge my batteries. The connections are different to the alternator and was wondering which wires would go were?
The larger one has one large spade connection with a smaller spade connection above and below it.
My alternator on Mudhog now has two large spade connections and one smaller one.
I have the plug from the later model alternator and the large alternator looks like it will fit on the old mounting bracket on Mudhog.
Just not that sure of the wiring, does anyone have any ideas?
From what I have found out about the larger alternator, it should be either 60-amp or 65-amp if it is a 25ACR alternator with the old one I have being a 40-amp.
Brett
