how to glow plugs
- BeamedSurf
- Bush Crasher
how to glow plugs
just bought a ln60 surf off samewan, it has trouble starting, he reckons its the glow plugs starting to shit out, does anyone know how to test if they are working properley? cheers
Toyota Hilux Surf SSR LN60 Beam Axle
Build in progress
Build in progress
uptomynutsinruts
Re: how to glow plugs
Ben, Take them out and put them across a bettery, you should see them glow up.
Mike
Mike
First check can be done in the truck.
Get a multimeter and check the OHMS...or continuity.
One lead to earth and one on the glow plug connection. You will have to remove the rail that connects them all together.
If its open circuit its dead.
Otherwise like has been said.
Remove, put body of glowplug to earth and touch the top to positive.
If its working it will start to glow........
- BeamedSurf
- Bush Crasher
yea will try when engines out of new truck
Build in progress
Build in progress
BeamedSurf wrote:yea will try when engines out of new truck
I had issues with mine. Replaced them. Cost a sh&$t load changed the relay etc. improved for 2 weeks then still had issues starting.
Fix turned out to be the $15 wire that fed the rail. Cost me just over $550 to fix that $15 wire.
Moto of the story check the wire that fed the plugs too.
ford ranger wildtract and sj.
- tomsoffroad
- Flopsie
Make sure they are 12v before you put them on a battery. Some are 7v (might be 9v) if I remember correctly
- BeamedSurf
- Bush Crasher
well im not entirely sure if its the plugs, the engine is in a dereg river hack and i dont think its had much use, plus the diesel in the tank is stale too apparently, this could be the problem? and if i run it in and have new diesel it should go allgood?
Build in progress
Build in progress
- niblik
- Sausage Shack
change the glo plugs for new beasties... diesel should be ok.. i know this top bloke who started this truck up a number of times easily before sam had it and it showed no issues...
give it a crack nigel...
- BeamedSurf
- Bush Crasher
hey niblik, u have no idea how many ks that things done ae?
i might just carry on with taking shit off an putting onto my truck then once its all there and goes then il get onto making it start easier, ive had it goin for ages, went down the ashley river last night, goes like charm mate, its just when starting for the first time after its been sitting for hours, so the glow plugs are a suspect in this situation
Build in progress
Build in progress
- BeamedSurf
- Bush Crasher
allgood mate, im not really that worried on the ks cos it runs mean, im just gonna do cambelt and shit when its been running for abit in my truck, also do u know what ratio the front and rear lsd is?
cheers Ben
cheers Ben
Build in progress
Build in progress
- BeamedSurf
- Bush Crasher
