camber bolts for suzuki
butcherboy
- Bush Crasher
i need some for my escudo does anyone in nz have them or am i off to bits 4 vits and do i need 2 for each side or just the one for each side thanks
Re: camber bolts for suzuki
Only need one per side, call up BNT, they should stock them. I got some off trademe ages ago, but don't think they are listed anymore. From memory they are 12mm.
butcherboy
- Bush Crasher
kernels wrote:Only need one per side, call up BNT, they should stock them. I got some off trademe ages ago, but don't think they are listed anymore. From memory they are 12mm.
thanks for the advice
I just remembered my bolts were Noltec branded and you might be able to get them from this guy: http://www.trademe.co.nz/motors/car-par ... 675896.htm
You could get them from www.streetech.co.nz
(Plug for father n law's business)
I used a set on the top and am going to get some for the bottom as I am not happy with my camber.
DISCLAIMER
