"Offroader" Turbo kit
For all Nissan related topics
Aza
Post by Aza »
http://www.trademe.co.nz/Browse/Listing ... =441873430
I know a few people have bought the manifolds before and had problems. . . but has anyone fitted their whole kit? wondering how much power would be gained compared to a standard td42 or td42t. Also has anyone used this brand of turbo before, what are they like? and when would boost come in and max out. . .
I should be putting a turbo on my safari later in the year, just trying to get some ideas
taz01
Tazzles
Re: "Offroader" Turbo kit
Post by taz01 »
http://www.offroadexpress.co.nz/Forums/ ... 1&start=90
taz01 wrote:
taz01 wrote:
on another note due to my issues with the fitting i complained to who i bought the manifold from who is offroader off tardme but is also Scarles Performance in auckland....... i at least expected an apology email ph call anything from them i also informed them that my input would be posted on the largest best 4x4 forum in nz (yes i admit i was hoping for freebees to shut me up :lol: ) ..... so 3 manifolds sent before one would line up with all the head bolts, then cutting 10/15mm off the bottom front corner to sit flat, small head bolts are needed to make a spanner fit, plus cut away the panel around the shock tower so the waste gate tube doesn't break off from movement of engine, the t3 threaded bolt holes don't align with the turbo these must be drilled out and nut and bolts used and lastly if you have a pto shaft its gonna be tight getting an exhaust to fit
even talking to them they tell me many of these have been sold im wondering how many other people having issues are these cheaper manifolds worth the hassle compared to the dsr ones my opinion 2c worth/bitch/complaint done
TD power wrote:offroader had a stuff up with supliler for manafolds 1st shipment hopefuly 2nd shipment sorted out
don't take any shit from these twits dude i barely got a apology outa them they even quibbled about courier tickets to send their cock ups back...... ring them mention taz from towbars having same shit problems and beware of the above other issues.....after mine there should've been no fark ups
WARNING:
JONO250
Post by JONO250 »
scored a brand new scarles turbo for cheap, same type that is thier kit. going fit it to my safari in the next couple of weeks, so will let you know how it goes. just by looking at it i get the feeling they are the same as any other chinese turbo, which have a reputation of grenading.
Aza
Post by Aza »
JONO250 wrote:scored a brand new scarles turbo for cheap, same type that is thier kit. going fit it to my safari in the next couple of weeks, so will let you know how it goes. just by looking at it i get the feeling they are the same as any other chinese turbo, which have a reputation of grenading.
sweet, thanks
crazyclark31
Post by crazyclark31 »
if your going to turbo it i'd get a manifold like that or the dsr one and fit either a tdo5 or a t28. you'll get same performance(maybe better) and a hell of a lot more reliability. Hand they handle decent boost levels.
It takes 15psi or more(with a cooler) to really bring the td42 to life and those chinese turbos tend to fail when running higher than standard boost levels.from my experiance anyhow
u13turbo
Post by u13turbo »
Nts about the TDO4, but with the T28 i wouldnt run anymore than 15psi, they are good turbos though, and at 14psi should last for ages, hell of alot longer than chinese ones. I had a dsr330 running 12psi on my sr20det and after 3,500kms the shaft play was incredible, wouldnt waste money on that shit again.
DaveM
Post by DaveM »
DSR no longer sell the manifolds, however, the "DSR designed" manifold is readily available on Ebay
TD power
Post by TD power »
hey mate in a few mouths offroader will have a full kit that will bolt on with 3inch down pipe or 2 inch that bolts to ur stock exaust pipe frount mount intercooler or top mount water to air or just a cross over pipe with an exchange sump service so no fab work testing turbos at the mo testing the scrt3t4s at the mo seems to be ok so far running 20 psi for 2 weeks so far comes on boost strong at round 2100 rpm will post more on full kit with pics
tgaguy1
Post by tgaguy1 »
TD power wrote:hey mate in a few mouths offroader will have a full kit that will bolt on with 3inch down pipe or 2 inch that bolts to ur stock exaust pipe frount mount intercooler or top mount water to air or just a cross over pipe with an exchange sump service so no fab work testing turbos at the mo testing the scrt3t4s at the mo seems to be ok so far running 20 psi for 2 weeks so far comes on boost strong at round 2100 rpm will post more on full kit with pics
Isn't 2100 rpm a little high for the TD42? What Rpm does boost start to build?
Jase.
TD power
Post by TD power »
starts to come on at 1100rpm can get 5psi free revving
crazyclark31
just as comparison my old truck ran a rebuilt td05 on a jpipe. and straight thru 3in exhaust. Was pulling 5psi at 1100rpm 15 psi at 2100rpm and held it right through to 5200rpm.
Pulled like a school boy all the way thru the revs.
I got high boost kit for the tdo5 which made it good for high boost use(elliminated the shaft flex).
As far as i know the truck is still going hard.
Return to “Nissan”
