I'd just like to introduce myself as a new Nissan owner. I have just bought this:
It's a '94 Safari Kingsroad, 4.2lt Petrol, Auto, blah blah blah. I primarily bought it as a tow wagon because I just upsized my boat and the Subaru Legacy just won't tow a 26 ft, 2 ton boat!
Now... I have a couple of questions for you experienced Nissan owners out there:
- I had a scare today when I moved it from 4WD low to 4wd high. I had the auto selecter in nuetral and moved the 4wd selector a bit slow betwee the ratios. As it paused in between (I did it real slow) something started to spin up and then I couldn't get it into high or low without it graunching hard out (it was spinning pretty quick). I put it in Park and it graunched/clicked for a good 5-10 secs before stopping. If I just move it between positions in one swift movement it's fine. Is that normal? If not, what could be the cause?
- In the future I will be looking to do a suspension lift and maybe put some bigger tyres on it. I'm not going to go nuts, but I just want a bit of extra clearance to be able to play with the bigger boys if I want. What is the most cost effective alternative and what do you think that I should aim for/avoid?
- Lockers? Options? Costs? I just saw someone posting about swapping in a whole factory locked diff. Is that the better option?
Anyway, that'll do for now. I'll hopefully become a more regular poster now that I actually own a 4wd of my own and not just tag along with other people (ay Mike
Mark
