nissan navara d22 +d21
For all Nissan related topics
te_rarawa
Post by te_rarawa »
hay guys just want to know if the 99 d22 navara venturer with the qd32 motor in it has the same diff or a diff that can bolt into a d21 4x4 navara .
do they both run ca48s?
tweake
Re: nissan navara d22 +d21
Post by tweake »
don't know about D21 but D22 certain doesn't. i think the D22 QD32 models used r180 front and H233b rear.
Tarmac
Post by Tarmac »
ca200 have a backing plate, 1st d22s run a h233 which has a nugget. As I understand they are just bolt in change as was mostly changed in the bodys (visual) but drive shaft flange could be different. Mine runs a 4.625? or similar, ca48 is the diff code meaning c200 4.8 guessing its a non turbo.
c200 is the ring gear in mm, around 8 inches. h233 you guessed it 233 mm ring gear bout 9 and a half, yup bigger than a ford....
The 2nd gen up went back to the c200 apart from the petrol, which also had the r200 front end as opposed to the r180. h233a also used in patrol fronts. Not a geek just looked into options, honest.
taz01
Tazzles
Post by taz01 »
c200 = 29 spline mk safari front
h233 = 31 spline rear mk or front gq safari rear terrano
WARNING:
Tarmac
Post by Tarmac »
http://www.navara.asia/forum
Look here, more answers than you have questions.
Open it all in a new tab and they wont boot u for looking at more than you should as a "visitor". :?
Return to “Nissan”
