Pajero fog lamps/spotlight swap
pouw
Post by pouw »
Hey guys, my pajero currently has two yellow foglamps wired and working. Could I swap the lamps for spotlights using the existing wiring or would this not work?
1986 2.5L TD Pajero
Cameron
Re: Pajero fog lamps/spotlight swap
Post by Cameron »
not really for road use: if you put spotlights on they need to be wired to turn off when your headlights aren't on high beam.
bit of simple wiring and a relay and you could sort that out, though.
I've got a set of dayrunners in place of those grot foglamps, which run off the stock switch.
pouw
Post by pouw »
Anyone here want a cash job of wiring the spotlights I bought to my high beam?
I can mount them and use the existing fog lamp wiring but understand I have to loop them into the high beam so that when high beam is off the lamps cant be used.
1986 2.5L TD Pajero
Return to “Tool Shed”
