4.88 hi pinion F/S or swap for 4.1 hi pinion
- muddyhilux
ok things have changed a bit.will be stripping 4.3 and and swapping locker but now looking at front end.
does any one have a 4.1 hi pinion out of an 80 series they'd like to swap for a 4.88 hi pinion ??
or does someone want to buy the 4.88 ive got and hopefully some one is selling a 4.1 i could buy?cheers all
Re: 4.3 locked diff swap for 4.1
pm sent
greg
greg
- muddyhilux
Re: 4.88 hi pinion F/S or swap for 4.1 hi pinion
bump
How much you want for it? Will be needing one soon.
- muddyhilux
enough to buy a 4.1.no more no less mate
Yep, I have 4.1 gears that where removed from an 80 e-locker that now has 4.8's in it. I've installed thethe 4.1's into a standard hi-pinion housing (2 spider open). It hasn't been setup thou. I'm keen for a swap. Maybe just a gear swap to save on shipping??
- muddyhilux
mhm.not really keen to rip apart a good working diff just to swap ratios.if you can get your diff set up I'd happy to swap though.i don't think shipping would be too much
hi ive got a 4.1 im keen to to sell
IM HARD AT WORK CANT U SEE THAT
- muddyhilux
awesome,is it also hi pinion?and did you want the 4.88 ive got?let me know how much you want for yours if you don't want the 4.8.ill then let the numerous guys who are keen on diff what its going to cost
muddyhilux wrote:mhm.not really keen to rip apart a good working diff just to swap ratios.if you can get your diff set up I'd happy to swap though.i don't think shipping would be too much
yeah ok, I'll get Rick at 4wd accessories to check it over. Is yours an open aswell? How quick do you want it?
- muddyhilux
kbjj,yeah give Rick a buzz and see what he'll charge to reassemble.that on top of potage and it might not be worth ya while,its all only just arrived so haven't confirmed if open but I'm sure it is.as for time frame it ain't tight.id say it'l take me to mid week / next weekend to get the head out anyway not to mention sas cut wont be started on till ive got motor back in vehicle and running and ute chop done so there's no big stress at this point
I've already assembled it, just need to set it up, Rick will check it over for bugger all. That way where both happy its a good diff. I can wait until youv'e got the diff out, as i do have an lsd unit that i could put in instead if yours is lsd
- muddyhilux
oh i wasn't aware they came out as lsd,better hurry up and pull it then ae.maybe hold off with rick until i can confirm
hey i will let it go $250 if u keen
