suzuki diff ratio
For all Suzuki related topics
butcherboy
suzuki diff ratio
Post by butcherboy »
can anyone tell me how i can find out what ratio i have
lilpigzuk
Tiger Balm
Re: suzuki diff ratio
Post by lilpigzuk »
butcherboy wrote:can anyone tell me how i can find out what ratio i have
pull the diff out and count the teeth on pinion and crownwheel :?
unless you might like to give just a wee bit more info...
Suzuki LJ10
Suzuki LJ20
Suzuki LJ50
Suzuki LJ80
Suzuki SJ410
Suzuki SJ413
Suzuki Samurai
Suzuki Jimny
Suzuki Vitara
Suzuki Grand Vitara
butcherboy
Suzuki LJ10
Suzuki LJ20
Suzuki LJ50
Suzuki LJ80
Suzuki SJ410
Suzuki SJ413
Suzuki Samurai
Suzuki Jimny
Suzuki Vitara
Suzuki Grand Vitara
they are out of a v6 thats all i know just want to see if someone has already put the 5,12 in already or if they are standard thanks
churchill
Post by churchill »
4.825 is standard for a v6 auto. 5.125's are worthwhile with 31's
Rotazuk
Post by Rotazuk »
Jack one wheel off the ground . Count how many times the drive shaft goes around for one revolution of the jacked wheel and then doule it . ie if the shaft goes around 2.5 times its a 5:1 diff . if it goes around 2.3 times its a 4.6:1 etc . will be too hit and miss trying to guess between a 4.8 and 5.12 .
strx7
Post by strx7 »
Rotazuk wrote:Jack one wheel off the ground . Count how many times the drive shaft goes around for one revolution of the jacked wheel and then doule it . ie if the shaft goes around 2.5 times its a 5:1 diff . if it goes around 2.3 times its a 4.6:1 etc . will be too hit and miss trying to guess between a 4.8 and 5.12 .
Actually, turn the driveshaft 2 complete revolutions, and your wheel will do either just shy of 5 turns or just over 5 turns telling you if it is a 4.875 or a 5.125
Return to “Suzuki”
