What needs to be done for a TD42 rebuild?
3rnzir
Post by 3rnzir »
Have been making inquiries to have a DTS turbo kit placed on my GQ.Compression is down on one of the clyinders.Truck done about 400K.1990 model.Been advised by turbo fitter to recco engine or get a replacement.I have seen an imported engine for $5K.Would I be able to get my engine recco`d for $5K or less?What would need to be done on such a job?
Cheerz
DieselBoy
Post by DieselBoy »
Everything apart from the mains can be done with the engine in place. rings, big ends, and the head would be the main onesi guess, but you would want the mains done aswell at those K's i would think.
There's quite a few on trademe that pop up in the 2k region that have done less than 200,000.
3rnzir
Post by 3rnzir »
Hi DB,thought about that option.But would I really be sure that everything in the replacement engine was OK?Was thinking at least with the recco option I would know for sure that everything is ligit.Having engine recco`d locally that is.How long does a recco take by a good diesel mechanic, usually take?
Cheerz
DieselBoy
Post by DieselBoy »
Not sure on time as i have never had one rebuilt (yet) but would have thought within a week in a good garage in a city with suppliers and specialist trades near buy.
A mate of mine down in westport payed $6000 for a complete rebuild after he hydraulic'd his TD42.
3rnzir
Post by 3rnzir »
Yep,that full rebuild price sounds similar to what I was just told.Went down to local engine rebuilders and had a chat.Around $3K for a in frame recco.
Cheerz
DieselBoy
Post by DieselBoy »
Yeah?? Doesn't sound too bad, what does that include??
Rings, big ends, full head recon, bore hone etc etc
You would have seen the Safari with the bonnet scoop in the pics from the last Thompsons trip??
He's got the bling turbo system ($8000), but one interesting tip i picked up from him was that they used the injector pump housing from a TD27 out of a Mistral with the boost compensator on it and swapped the internals from his TD42 pump into it. Something worth keeping in mind i thought :wink:
DaveM
Post by DaveM »
How much you looking at paying all up? (pump,turbo,rebuild)
Also, where did you get your injectors from? Considering doing mine at the moment.
Dave
mudchuka
Post by mudchuka »
why not buy a truck witha turbo engine and swap it over? thats what i did, i purchased a 1988 lwb safari with a aftermarket safari brand turbo for $6500 and swapped engines with my swb, also took the pto winch, bullbars, tyres,heavy duty clutch and 3" exhaust , put my parts back on it and then sold it on trademe. the whole exercise cost me $800, that included paying a mechanic to swap the engines.
JTop
Post by JTop »
You can replace the bottom mains in place and these are the ones that take all the loading, if you want to do a cheap rebuild. Remember TD42s run can have a low oil pressure problem when hot. Also check the pump.
J Top
GQTROL
Post by GQTROL »
Dave,
We can rebuild your injectors with new nozzles and re-set the breaking pressures for $80 / injector if you're interested. I think we've got a spare set somewhere that we can use as exchange, so you're truck isn't off the road for too long.
Mitch
doddzee
Is Doddgee
Post by doddzee »
If you have done 400k this ones still got annother 200 in it.
http://www.trademe.co.nz/Trade-Me-Motor ... 365246.htm
3rnzir
Post by 3rnzir »
DaveM
It`s looking like this maybe the price breakdown.
Engine recco $3500
Modified injector pump $2000
Turbo DTS plus fitting $4000
3" exhuast $400
Makes Mudchukkas` option look good eh.
May want to get those injectors done.Last time my were done apparently was 1995.Replaced a seal/gasket around water pump,new radiator hose,
sonic bath injector nozzel and washers etc.$730inc.
I think I will register myself in a small bussiness before I go ahead with the above.Sounds like alot of $.Though not compared to a new rig.
$600-$650 should be enough for you to have o/hauled injectors.
New vehicle emission test comming into effect this Oct.I belive.
safari_mulisha
Post by safari_mulisha »
my mate steve has one for sale for 2g with 138ks on it
DaveM
Post by DaveM »
safari_mulisha wrote:my mate steve has one for sale for 2g with 138ks on it
What does it include?
DaveM
Post by DaveM »
Flicking through a couple of old(ish) mags, there was a TD42 with 5000km on it for $10k.
Was pretty much a brand new motor by the sound of it, turbo, 24 and 12v alternators
billyvanboheman
Post by billyvanboheman »
GQTROL wrote:Dave,
Have you had the injectors done yet DaveM
GQTROL
Post by GQTROL »
Dave,
That was Kevvy Knott's engine from AU. The 5000kms is all comp work, but it was built with the right internals and has had ALOT of fuel pump work done by Hiway Diesel Services in Coopers Plains. But since Kevvy rolled that truck a week ago, its probably not the best donor for a transplant.
DaveM
Post by DaveM »
billyvanboheman wrote:
GQTROL wrote:Dave,
Hmmmm, how did I miss that one :roll:
Mitch, if the offer still stands, I'd be keen to go ahead with the injectors. Sorry, missed the original post for some reason.
Dave
GQTROL
Post by GQTROL »
Yup, no problems Dave, offer still stands.
Just send them to address below:
Diesel & Turbochargers,
40 Tallyho St,
Rotorua.
Attn: Aaron
Let me know when you're about to send them, so we can make sure we get in new nozzles. We can usually turn them around and have them back to you within 7 days. Just remember to include return courier address ;-)
I replied to your diff lock solenoid question on NZ 4WD forum.
Mitch
krawlr
Post by krawlr »
thats a good price dave :wink:
Return to “Tool Shed”
