sc14 in a surf?
skidmark
sc14 in a surf?
Post by skidmark »
got a 3 liter v6 surf that im thinking about adding a sc14 supercarger(yes i know about the headgasket issues...) but with the vaccuum operated add and what not on the front diff,is it going to try and dissingage the front end when the motor is making boost? due to the lack of vacuum?
cheers Alistair
Pedro
Re: sc14 in a surf?
Post by Pedro »
Add a vac canistor with non return valve and run the servo off that
Pedro
skidmark
Re: sc14 in a surf?
Post by skidmark »
oh sweet thats a easy solution to that then! cheers.
will start collecting bits
tweake
Re: sc14 in a surf?
Post by tweake »
would there be room to add a SC14? also its a bit under sized for that motor.
TRD used eatons (i think) in their kit for those motors.
pruggerdore
Re: sc14 in a surf?
Post by pruggerdore »
tweake wrote:would there be room to add a SC14? also its a bit under sized for that motor.
guys advertising sc14's on trade me reckon up to 4.0 litre. not true???
tweake
Re: sc14 in a surf?
Post by tweake »
the supercharger comes off a 2 litre engine. it may flow enough for a 3 litre but it will be spinning a lot more rpm to get some decent boost. they tend to make a ton of heat so you need to intercool somehow. high rpm and high heat are not good for those rotors.
i'm sure you could fit it on a 4 litre but how much boost you make and how long it lasts is debatable.
the eatons, like what the holden engines have, is far more efficient and makes less heat.
skidmark
Re: sc14 in a surf?
Post by skidmark »
it would be tight but i think it will,just... yea im not going to be going for mega boost prob only around 5psi just to give it a bit more go.otherwise 1uz...
Pedro
Re: sc14 in a surf?
Post by Pedro »
Ran one on a 3.8v6 at 5psi. No problems, had it for 4 odd yrs
Pedro
skidmark
Re: sc14 in a surf?
Post by skidmark »
Pedro[/quote]
mint should be fine for what i want then!
pruggerdore
Re: sc14 in a surf?
skidmark wrote:Ran one on a 3.8v6 at 5psi. No problems, had it for 4 odd yrs
Pedro
mint should be fine for what i want then![/quote]
yep me too3.8 in fact on an engine that (i belive) pedro put in a pajero like 10 years ago?? Now in a hilux.
I guess for offroad and low boost isnt really asking much of it
Return to “Tool Shed”
