04 hilux any ideas,
front mount ooler air more expensive to fit more piping, or front lest piping less lag easier to fit
any help appreaciated
top mount vs front mount interooler
Re: top mount vs front mount interooler
a front mount will give you larger gains and more benefits from fractionally more cost, something in the 450x180mm or 240x230mm size will be highly adequate for your hilux and use 2 inch piping on it.
you wont notice the lag difference unless you use a massive IC and 3 inch piping
