So a mate of mine is thinking of upgrading the rear springs in his 96 wizard. want to be able to carry a bit of weight with out sagging etc..
Has anyone out there done the same, if so what did you use ? Thinking about a spring shock combo for around 300 kgs load i guess..
any thoughts\comments\exprience ?
wizard spring upgrade, anyone done it ?
Wellyranger
- Driver/Navigator
- KIWI_TERRANO
Re: wizard spring upgrade, anyone done it ?
Mate used bighorns. Infact his trucks on trademe now
i have cobra springs in the rear, not sure of the load rating but the havn't sagged much really, had them a while now. also i don't tow much. but they're pretty stiff. bretty much anything (springs, shocks, diffs) from bighorns, or made for bighorns will fit in a wizard. hope this helps
