Grand Vitara transfer
For all Suzuki related topics
unadunted
Post by unadunted »
Gidday Guys. What could be the problem if a Grand Vitara transfer lever can't be shifted? Apparently hasn't been used in 4WD for ages. I know the SJ's problem where the shifter stuck due to worn shifter sheet. Would this the same thing?? Thanx in advance.
churchill
Re: Grand Vitara transfer
Post by churchill »
Silly question but have you tried putting the gearbox in neutral before shifting the transfer lever? I know mine will only move into low in neutral.
unadunted
Post by unadunted »
Ta Churchill. I haven't seen the car and not familiar with them. Was told the lever won't shift at all, not from 2wd to 4wd or into low. Rob
Return to “Suzuki”
