Firstly I had to fix a few problems
1. Oil leak
Oil was leaking from the side of the block somewhere, we couldnt quite figure out from where??
I replaced every seal that was easily accessable. Covers, sump etc, but that didnt fix it.
After poking around with a small mirror on a telescopic rod, we discovered it was leaking from behind the injector pump.
A quick look at the manual confirmed there was an O-Ring here that may need replacing.
The price for the O-ring was $5.00, but the time involved was over 5 hours!!
So away we went, and just as we thought the O-Ring needed replacing, so the cost was
PARTS = $5
LABOUR = $300
2. Water Leak
As with most Japanese imports, they always have a few leaks.In this case I decided to simply replace the Water Pump, so I have trouble free motoring for a while.
Check around when doing your water pump as I had quotes ranging for the pump from $80 to $300, this was not including labour to fit it!!
Total cost to replace water pump was $120.00
Next mission - Is to find out why they have 2x 12 volt batteries? I suspect one is for cranking and 1 is for evertyhing else!
Any ideas.
I want to see if they work together or independantly.
