3.9 upgrade help please
hi has anyone fitted the injecton manafold and bosh injectors from a 4.6 twin intake v8 to a 3.9 it all bolts on but dose it work 3.9 has had rebuild done and hi tork cam any help would help thanks
Re: 3.9 upgrade help please
Don't know if the manifold will work, more than likely will, but the Aussies are using bosch ford injectors and apparantly give more power and much better economy.davey32 wrote:hi has anyone fitted the injecton manafold and bosh injectors from a 4.6 twin intake v8 to a 3.9 it all bolts on but dose it work 3.9 has had rebuild done and hi tork cam any help would help thanks
Would love to know if it does work......pls keep posted if you can
