Got a twin fan Radiator out of a V6 Honda the other day and was only after
the fan off it but the whole thing is mint so I'm thinking of chucking it in the back ( soft top Suzuki bush truck ) but I need some pipe to plumb it in, has anyone north of Auck's got anything lying around that would be suitable?
cheers AL
Rear Mount Radiator Pipe
Re: Rear Mount Radiator Pipe
Hey
I used exhaust tube to do mine. Got 38mm (i think) cause it fitted Darinz bender. Was about $50 for a length, bent it up and put a bit of heat padding over it as it runs in the cab.
- Sadam_Husain
- Angry bird
dosent really answer your question but just a thought to throw into the equation, beer_cruiser stuck a spare cruiser radiator on the back of his 40 and plumbed it up to the heater outlets on the engine (no heater in his truck
) and ran it in tandem with the radiator on the front of the truck, seemed to work ok
while back i had the idea of using hydr hose off a large digger
WARNING:
taz01 wrote:while back i had the idea of using hydr hose off a large digger
sounds like $$$$$$$$
Sadam_Husain wrote:dosent really answer your question but just a thought to throw into the equation, beer_cruiser stuck a spare cruiser radiator on the back of his 40 and plumbed it up to the heater outlets on the engine (no heater in his truck) and ran it in tandem with the radiator on the front of the truck, seemed to work ok
Now thats a good idea, crafty if you could tee into heater circuit, then use heater control to operate a 'gate' valve at the tee if you get my drift.
- Dr_PC
Al,
19mm aluminum cheap as but cant remeber exactaly give ulrich a call, thats what I'm using
Dr_PC wrote:Al,
cheers Dan
