SJ413 starter motor
SJ413 starter motor
The starter motor in my sj413 is stuffed
and when i pulled it out it had a mitsubishi logo on it ,I was just woundering if there is another vehicle that has the same starter motor as a 413 that i could use as a replacement.
I was going to rebuild it but the housing the main shaft sits in is pretty worn out and i think theres a bearing on the shaft and thats rusted solid
.I've heard that holden barinas have the same engine as a 413 so i might go to pick a part tomorrow to see if theres a barina there to compare starters and see if there the same.
Jamie
Jamie
Ahhh you made it home then.......I had horrible overheating (hopefully just mud on the radiator) It may not just be the bushes, my daihatsu one melted when it died.....I can ask around I know a couple of people with Zuks locally who may have spare parts
Otherwise just swop your motor for Mr Offroaders...I'm sure he won't notice or mind too much !!
Re: SJ413 starter motor
redzuki wrote:The starter motor in my sj413 is stuffedand when i pulled it out it had a mitsubishi logo on it ,I was just woundering if there is another vehicle that has the same starter motor as a 413 that i could use as a replacement.
most trucks and cars have some sort of electrical bits made
by mitsubishi....
- mroffroader
redzuki wrote:I ve had that 1.6 on my eye for a while
OI! get ur filthy eyes off my vitara! get ur own.....blardy!
80 series tow bus towing a redneck ass vitara
I went to pick apart and pulled a barina starter motor out and the front of the starter housing was different so i tried to change the front but it didn't work the main shafts where different sizes:( .
So i went to repco and got new bushes ,new brushes , a new bearing and a new gear that engages into the fly wheel for about fifty bucks,so now ive just got to go and fit it all .
Jamie
Jamie
redzuki wrote:I went to pick apart and pulled a barina starter motor out and the front of the starter housing was different so i tried to change the front but it didn't work the main shafts where different sizes:( .
Jamie
good stuff. youll be zuking again in no time.
- mroffroader
WACKO wrote:redzuki wrote:I went to pick apart and pulled a barina starter motor out and the front of the starter housing was different so i tried to change the front but it didn't work the main shafts where different sizes:( .
Jamie
:groupjump: yippie!
