Well as the title says I want to know how much you guys think my zuk and all its associated stuff is worth as I am trying to weigh things up at the moment and see where I should go to next.
So basically:
1993 Vitara
8 Valve carby
300+km
SWB
Manual
comes with:
new chassis, rear diff, gearbox, front diff, petrol tank from an efi, two lots of spare front suspension (a-arms, struts, sway bar, steering, spare set of zuk rims, LWB springs, has coby extractors fitted with a 2.25" exhaust, spare set of front seats, spare trailing arms, top diff mount (rear), spare head light, clear braxton tail lights, spare doors (both escudo and one for each side, comes with glass in), two spare right front guards (Escudo), Guard side repeaters for escudos, spare rear glass, does have the original bumpers too (not fitted), spare off road bonnet
May also come with spotties
I also have 16" grand vitara rims with 225 70 muds on it with at least 8-10mm tread with tubes
So peoples thoughts on price(s) please.
Lincoln
How much do you think its worth?
Lubrication Specialist
Lubrication Engineers
- Sadam_Husain
- Angry bird
Re: How much do you think its worth?
if it was a complete running 8 valve carby zook reg and wof probably $2-3k at a guess so if its a stripped down bunch of parts it would be whatever you can get for them, unfinished project vehicles are hard to sell for what you want
yea, reg is on hold, current chassis has a bent cross member, hence why i got the new chassis
carb needs new jets, it does run just doesn't rev due to fuel starvation as I think a jet is blocked.
Its all together at the moment minus the bumpers so not really stripped out.
I sold a rego'd and wofed LWB 1.6 manual with 160k kms on it 6 mths ago for $1500.
