10th & 11th March
andy3542
10th & 11th March
Post by andy3542 »
Ill start this one...
Had an interesting afternoon/evening. Picked the Landy up from the garage new alloy radiator and fan fitted all ready to go play tomorrow. On the way home suddenly heard a whining followed by the loss of all drive (on the entrance to the greenland roundabout at 5pm). jumped out to find that the pinion on the rear diff had failed causing it to fall out. put her into 4wd only to find that the rear diff was locking up... i had no tools with me so had to wait until Brad (my new Bmw mechanic friend who deserves a beer) pulled over and let me borrow his socket set so i could remove a half shaft and carry on my way. showering the cars behind me in diff oil. (didn't realize until i got home)
so an apology to all those who were held up by my trucks failure and anyone who was showered in diff oil...
now got to pull the rear and front diffs and change them over as i don't have a spare 4.1.1 ratio land rover diff... :( and as anyone whose worked on a series land rover will know the fronts are an absolute c**t to do.
Offroad Addiction TV
lincooln
Re: 10th & 11th March
Post by lincooln »
that sucks bro. so much for playing. My big achievement was looking at my zuk and thinking that I should lock it up with all my parts in it and all. Still not done. :roll:
Might get some cleaning ready for painting done this weekend if the weather is shit, otherwise it's removing the head on my Fuego Turbo
Lubrication Specialist
Lubrication Engineers
tweake
Post by tweake »
still tweaking the surf.
fitted 88c hiflow thermostat. had a 82c one in (as per typical mod to save the head) but was having combustion problems when over 3k. its runs a lot better with the 88c but temps have gone from sitting rock hard on 82 to 90-92c.
now to see if the radiator is going to hold up.
made a extended brake load senor valve bracket, on number two model,seems to be doing the deed, needs brake machine to test properly
Nis-man
Post by Nis-man »
Discovered a brake fluid leak from the block on the front diff where the flexible hose meets pipes that go to the front calipers. At some stage one of them had been overtightened and the coupling had almost pulled over the flare. Took it down to Autostop the put a new coupling on it and made a new flare.
Noticed shorty was also pulling to the right under braking so greased the caliper slide and swapped one pad from one side to the other, if it is still not right I will need to do caliper kits. Finished king pin bearings and wheel bearings, repacking cv's etc last weekend.
SP450andLE
Post by SP450andLE »
I'll be finishing (or at least attempting to finish) the high mount alty.
Pic to show how it is so far:
Del Fuego
Post by Del Fuego »
Looking slick brother!
SP450andLE
Muchly thank you. It's been some hard work, but it's almost there. I'll get an auto sparky to do most of the wiring on it, saves me from stuffing round with it and causing (more) fire hazards :lol:
Del Fuego
Post by Del Fuego »
should be cheap enough/not all that complicated I wouldn't have thought?
SP450andLE
My mind isn't electrics-compatible :lol:
Sorry for spam everyone :?
Del Fuego
Post by Del Fuego »
Oh... yes, shall take it to the projects discussion :)
This weekend I shall be hacking more bits of Niva off Niva to make it better/enable mud action (just for some on topic discussion)
ladeda
Post by ladeda »
SP450andLE wrote:I'll be finishing (or at least attempting to finish) the high mount alty.
sweet bro looks like ya got the belt set nice and straight. adjuster bracket look a bit stronger using both rocker cover bolts like ya have.
Verry nice.
Ive started marking and cutting up the plate to do the same on mine, who knew you can cut 3mm plate with a jigsaw (ran out of cutting discs) :lol: :lol:
SP450andLE
Yeah, it's a bit misaligned when it's tight, but it should be an easy fix.
Can't cut 5mm steel with a jugsaw. A grinding wheel works though (I, too, ran out of cutting discs) :lol:
kbushnz
Post by kbushnz »
Ahhh well the plan is to finish off the trans install....
Just got to install the drive shafts and check the fluid levels...
Went thru 18L of ATF fluid when I flushed her out.... :shock:
At least now its full of clean fluid.....
Then its onto the pto shear pin up size and light install for Easter....
Oh and I may get a visitor to tap in an EGT probe in his Prado....
Jay
Post by Jay »
I'll be finishing off an engine swap in an TD27 - R50 Terrano, bolting it all back up, plugging it all in, filling it all up with nice clean fluids and all going to plan.....turning the key....... :)
Jay
put the front of the truch up for front axle swap, stand works well
pulled of dump valve pipe work, dump valve never actived
taz01
Tazzles
Post by taz01 »
front bar done painted now no more major welding left to do on the gq-panda
WARNING:
monstr
Post by monstr »
Spent the day in Woodhill ,have finally sorted the last tracks to be done for the 24hr challenge ,Many thanks to Warren (4wd bits) and Dion for their help .we have quite a few very long stages that will have the teams saying "are we there yet" :) and only 3 reasonable short ones but even those should take the teams 30/40 mins to do each stage :wink: .Roger the park operator has spent alot of very long hours making new tracks with a digger that will be open for the first time for our comp so should surprise a few of the locals that know the park well ,"Roll on Easter"
meatc
Post by meatc »
Spent today doing some clearing on the tracks we are going to run in our Winch challenge. One word summons them up :twisted: :twisted: NASTY :twisted: :twisted:
kbushnz
Post by kbushnz »
Sweet Monstr, looking forward to it......
Fixed my leak.... and now can concentrate on the lights for Easter..
Also put in the EGT probe for Ginzu8...
ladeda
Post by ladeda »
Made this up with with my new sca welder today
stuck this here ready to position and weld on alternator bracket when I a find a cheap high output one to replace origional one. doubles as blanking plate for old mechanical fuel pump hole.
spent the afternoon drinking and bbqin up. 8)
Heath
Post by Heath »
Stripped out some of the dash ready for the heater core swap over (hope this fixes the bubbling sound under the dash - done everything else but a new engine). While its apart I will get the new stereo sorted too.
Last week at FH for me this week (finish on completion of my shift Wed), have a fvew days off to get back into "day worker mode" before I start at the new job.
suzookyman
Post by suzookyman »
meatc wrote:Spent today doing some clearing on the tracks we are going to run in our Winch challenge. One word summons them up :twisted: :twisted: NASTY :twisted: :twisted:
:evil: wish I could have been there, you going out again? AL
niblik
Post by niblik »
1 SLEEP!!! :mrgreen: :mrgreen: 8) 8)
ClassicCruiserSpares
niblik wrote:1 SLEEP!!! :mrgreen: :mrgreen: 8) 8)
Aint going to get much sleep! :D :D
DieselBoy
Post by DieselBoy »
Envious as :lol: :lol:
Get lots of pics for me :mrgreen:
Heath
Post by Heath »
Heath wrote:Stripped out some of the dash ready for the heater core swap over (hope this fixes the bubbling sound under the dash - done everything else but a new engine). While its apart I will get the new stereo sorted too.
On my way to work I discovered that with the centre console removed and the radio surround out that my indicators didnt work. Seems the hazard button needs to be in place for them to work - Who knew that - LOL
wjw
Post by wjw »
hahah, I found that out on my cruiser :-)
Well I managed to replace one front flare with rubber (that came off at speed last weekend), replace the wifes brakepads and replace pistons and pads on the rear of the cruiser....
Who knew Prados could fly?
NJV6
Post by NJV6 »
Your turn will come...
SP450andLE
I found out that the bottom mount for the alty was wonky, so I started to make a new (read: better) one. In between the showers of rain :lol:
