Hi from the US
Tan Zuk
Hi from the US
Post by Tan Zuk »
Hi Everyone,
I live in Pompano Beach, Florida and this is my 1987 Samurai JX Build.
(This is one of my Bucket List Builds so it is a bit over the top)
Hope you will be interested :D :D
I will start off with the before and in progress pics because it is still being built.
Finally got the front suspension together enough to roll the Rig outside for the first time in a year and a half.
My buddy stopped by today with his stocker. Thought that you would like to see what that looks like next to the big one while it was out.
For those interested in the lift dimensions:
Stocker is 15.5” to the bottom of the rocker panel.
Big one is 36” to the bottom of the rocker panel.
There is a 20.5” difference in lift from the stocker to the big one.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Here are the suspension and drive train stats:
88" wheelbase, 84 inches tall, 82 inches wide.
Front frame extended 8 inches rear 3 inches
4 1/2 inch YJ lifted springs
Toyo 38's and 16x12 wheels
85 Toy front axle with all Trail Gear inners including Trunion Bearing Eliminator
529 gears open and High Pinion, 6 Shooter Knuckles with High Steer and 1 inch
Space.r
Rear axle is Trail Gear offset Sami Toy housing, 529 gears open and 1.5 spacers,
Rear Disk Brake, Outboard Shocks.
FJ80 steering box, Panhard bar and Rancho 9000 36" length.
ZOR Snatch
6.5 Transfer Case Gears
The trans will also be gone through
No driveshafts yet
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Here is the motor. I have a small machine shop and machined a lot of the parts for the
motor, suspension and steering mods.
Here is the Before Pic
After
Motor: 1.3 .020 over and deck shaved,
I used dish pistons because of the decking,
1.6 Reynolds ported polished and larger valves and shaved head.
Adjustable timing gear was used because of the shaving of the head and block.
I also had to make a custom timing adjuster wheel. It was too small in diameter and was unable to get the timing belt tight.
Internals are balanced and flywheel,
I'm going to use a Centerforce clutch this time.
The intake was made from a solid block of 6061. It started at 35 pounds when the machining was done it was 8 pounds. I also decided to machine the water ports in the manifold.
The carbs are 32mm Katana GSX-F.
The external accessories on the motor I have also machined up.
The distributor has been switched to mechanical.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
If you are interested in a build thread. Please let me know.
Thanks
chop
Re: Hi from the US
Post by chop »
wholey smoke that is one awesome rig! well done indeed
Built not brought
yeti
Bruiser
Re: Hi from the US
Post by yeti »
Tan Zuk wrote:If you are interested in a build thread. Please let me know.
Thanks
post away fella, .........and welcome to the site :wink:
v8 tj...luvs the gas......
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
chop wrote:wholey smoke that is one awesome rig! well done indeed
Thank you Sir for the compliments.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Thanks
Thanks for the Welcome.
Question is this the place to continue a build thread, or do I start a new one in the build section? Thanks
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Please feel free to click on the link to hear the motor run.
:shock: http://www.skyscomputers.com/pictures/friends/Zuk%20Motor.wmv :shock:
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
I also do fiberglass work ( Not By Choice)
After installing the front Shrock Work bumper it looked like it was missing something. I decided to make a lower valance to conceal the 8” frame extension. I’m also getting a bit older and needed an additional step. I decided to make some running boards for the 2nd step. The back tire is being used as the 1st.
The bumpers, fiberglass pieces and the body moldings were Rhino Lined to match the paint for durability.
Front Lower Valance
Side View Running Board
Rear Side View Running Boards
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Front Frame Extension is 8” and is level to the ground instead of following the frame. I also smooth out all my welds. This tends to add a lot more time to a build just my preference.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
The Rig is rather high as you can see. This presented some unique problems trying to get the steering geometry setup without a steep angle. I will go through the mods and the parts that needed to be made to correct the problems in the next couple of posts.
I also have an unusual steering set up with the FJ80 box, Lifted YJ springs and the addition of the Panhard bar just to make it more complicated. There is not a great deal of room to work with when you have to add a shock tower in the mix on the DS.
Steering Front View. I still need to do some welding and fitting yet.
The steering geometry is set at 5 degrees.
Panhard Bar was bent at one end to 5 degrees to shorten the PS mounting bracket. I have a 3/4 Heim in the DS and will be using a suspension bushing on the PS. This will help the bar from flopping with the bend in it.
Extended High Steer Arm was made from 8620 the same material the 6 shooter arm is made out of. These pieces will be tig welded together. The block started off at 30 pounds. After several hours of whittling I got it down to a more manageable 9 pounds.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
To help eliminate one problem:
I started off by dropping the FJ80 box 1” to help decrees the drag link angle. The Frame was notched 1” and the holes filled in the frame before adding the frame plates. This was done to the inside, outside, top, bottom and the notch.
1" Frame Drop Mod
1/4 Outside Drop Plate
Outside plate mounted with DOM bushings and rosset welding holes.
Inside plate mounted
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Now that I have the FJ80 box mod done. The next issue was mounts for shocks, panhard and bump stops. This took me quite a while to come up with something to incorporate all of this into 2 mounts.
Note:
These mounts were made to sandwich over the TG Shock and Ball support Brackets on both sides.
Driver Side (Side View) Shock Mount and Bumpstop Pad
Passenger Side (Rear View) Shock Mount ,Panhard Bracket and Bumpstop Pad that still needs to be added to the top.
Passenger Side (Side View) Shock Mount ,Panhard Bracket and Bumpstop Pad
Passenger Side (Front View) Shock Mount ,Panhard Bracket and Bumpstop Pad
Drivers Side Frame Panhard Bracket and Lower Bumpstop Mount
NOTE:
Thought I would add that I switched over to the 6 shooters after the pics were taken.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Note:
NOTE:
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
This is the side that got to be very congested.
Components:
Fj80 Box
Panhard Bar Bracket
Ford Shock Tower
Mods:
1" Frame Notch
Frame Plating
Bump Out for the Steering U-Joint and Box Plating
Drivers Side Bumpstop Mounting and Pad Locations. There will be additional bracing added to the Panhard Bar Mount for the stress of the Bumpstop Action.
FJ80 Box 1/2 Extension Block. I added this to lengthen the Drag Link. This will also cut down on the angle and decrease the rotational effects of the Panhard Bar.
Note:
The Drag Link length is 37 1/2 inches. Anything over 36 inches is ideal for a Panhard Bar applications.
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
There was a preview of the build.
Question, does this build need to be moved to the build section???
Thanks
zukmeista
Re: Hi from the US
Post by zukmeista »
I am speechless :shock:
Tan Zuk
Re: Hi from the US
Post by Tan Zuk »
Decided to move this over to the new projects section.
Here is the link:
http://www.offroadexpress.co.nz/Forums/ ... 18&t=29739
