Priming a new motor build with oil
I have been a Chevy motor guy for awhile now and have built up a few motors. You can use the distributor pickup drive adapter to spin to prime the motor. This is simple enough.
I was very concerned about starting what is known as a dry engine. The Zuk motor has no real way except the starter motor to do this priming, The problem with that is it spins a bit too fast, it will cause friction and you still really don't have any oil in the areas that are critical.
I did find a work around. Not the best way and it is messy and a bit time consuming.
Better safe than sorry.
I pulled the plug fitting off the pass side oil pump and threaded a pipe fitting with a 3/8 hose end on it.
CAUTION:
You have to be careful treading the fitting in because the threaded hole is a (BSPT) British Standard Pipe Taper thread. Put some thread sealant on it and just snug it. Then pump in 2 or 3 quarts of oil.
I used a suction pump I got at Harbor Freight.
This will push oil up through all the passages. When you have finished (this is the messy part) take the fitting out and reinstall the plug and use thread sealant on the threads. This should also fill up the oil filter as well. I also put oil in the filter and let it set for a while to let it soak the oil up and then install. Be sure you do this before the priming is done.
Then put the remaining quarts you have left in the oil fill in the valve cover. Now you can use the starter motor
CAUTION: DO NOT continually crank the starter!! Do it in intervals you can still create heat.
It is still not going to pump up immediately but everything that is critical should be coated from the priming you just did and the assembly lube that I hoped you used.
I did mention earlier about those oil plugs that need to be re threaded above the oil filter to NPT. It would be a good idea to install an oil pressure gage in one of those holes now to monitor when you get oil pressure.
(THIS WILL STILL NOT SHOW UP IMMEDIATELY BE PATIENT)
CAUTION: BE SURE TO PULL COIL WIRE BEFORE CRANKING THE STARTER.
When you get the pressure it is now safe to start. Run at about 2000 RPM for 20 min for break in.
The pic will have an arrow at which plug to use to prime with.
