The trans is not talked about too much and being in the process of rebuilding the one going in this build. Thought it would be a good time to share a few tips and tools that were picked up on in a couple of pervious rebuilds.
Reference Rebuild Info:
This is a good step by step and pics
http://www.geerdijk.com/files/suzuki/tranny_rebuild.pdf
The FSM will be needed for a few things that were not covered.
This is my minimum parts list and parts # from LROR.
1----STM-ISR-----------Samurai Transmission Front Input Housing Bearing Retainer
2----STM-CRSB--------Samurai Clutch Release Shaft (throwout) Bushing
1----STM-TNB----------Samurai Transmission Needle Bearings
1----STM-RRTB--------Suzuki Samurai Transmission Tail Shaft Bushing
1----STM-UTM---------Unbreakable Rear Transmission Mount
1----SDT-TBS----------Samurai Transmission Shifter Bolt 86-89
1----STM-TIP-----------Samurai Timing Inspection Plug
1----SDT-TMBN--------Samurai Nylatron Transmission Shifter Bushing
1----STM-RKS----------Samurai Transmission Rebuild Kit w/ Syncros And Silicone
1----STM-CRSOS-----Clutch Release Shaft (Throwout) Oil Seal
There are a few grey areas I will try and shed some light on.
The countershaft installation is one of those grey areas. This is the procedure that works well with a press, mallet, couple of sockets and a piece of pipe.
Pics are marked in detail
