Anyone know what size and thread the 1-HDT coolant drain is?
Also what are the rules about bolting things to shock towers? need to make 3 10mm holes
Thanks,
Bill
We are Borg wrote:I can measure the drain cock in My cruiser tomorrow if it is the same as the ones on an 1hz
snotgoblin wrote:given the rules around corrosion within 200mm of shock mounts, I am picking that drilling is a no no depending on where?
what are you mounting?
wjw wrote:snotgoblin wrote:given the rules around corrosion within 200mm of shock mounts, I am picking that drilling is a no no depending on where?
Engine coolant heater, has to be down low and in the US they mount them to the shock mount on 80's. Can't find space anywhere else
We are Borg wrote:Just had a quick look and by my eyeballometre i would say that it is 10mmx1.25 ( or 10mm metric fine)
wjw wrote:We are Borg wrote:Just had a quick look and by my eyeballometre i would say that it is 10mmx1.25 ( or 10mm metric fine)
Great thanks, the part that came with the heater won't work
