Fj40 Handbrake
Fj40 Handbrake
Hey guys
I've just put a H55 gearbox into my truck, upgrading it from the stock 4 speed. The handbrake setup on the old box was on the driveshaft, in the form of a drumbrake. That's gone.
What I need is to make up a new handbrake using the rear drums, or by upgrading those drums to discs. I've seen conversion plates in the states, but those are for american monte carlo style rotors so I'm buggered if I know what the japanese equivilent is.
Any ideas fj40 fans?
- ClassicCruiserSpares
- Sausage Shack
Re: Fj40 Handbrake
You could fit a BJ40 fully floating rear diff in which has the handbrake on it and also fit a BJ40 handbrake setup to it. The fully floater can be easily fitted to discs also if you wanted discs on the rear.
Re: Fj40 Handbrake
Is it the same dimensions as the fj40 diff?
- Sadam_Husain
- Angry bird
Re: Fj40 Handbrake
yep but make sure you find one with the handbrake on it coz not all 40 full floaters have them, I think the 4 bolt backing plate ones do and the 8 bolt backing plate ones still had the handbrake on the gearbox
- Sausage Shack
Re: Fj40 Handbrake
Pj_Marsh wrote::D
They sure are bolt straight in.
- Sausage Shack
Re: Fj40 Handbrake
Sadam_Husain wrote:yep but make sure you find one with the handbrake on it coz not all 40 full floaters have them, I think the 4 bolt backing plate ones do and the 8 bolt backing plate ones still had the handbrake on the gearbox
This is correct but the eight bolt ones only came out factory in the FJ45s 80-84.
- snotgoblin
Re: Fj40 Handbrake
Not meaning to but in... but...
My 1980 BJ40 has the cardan shaft handbrake just aft of the g/box, just a bigger version of that on a SJ413 zuk...
Did all BJ40s come with full floaters?
- Sausage Shack
Re: Fj40 Handbrake
snotgoblin wrote:Not meaning to but in... but...
Is it a BJ40 not a BJ41?
Re: Fj40 Handbrake
Looking at pics,does'nt look like theres any handbrake.
- snotgoblin
Re: Fj40 Handbrake
ClassicCruiserSpares wrote:snotgoblin wrote:Not meaning to but in... but...
Yep definitely a 40 - according to the tally plate anyhow. Chassis number syarts with BJ40 - XXXXX
- Sadam_Husain
- Angry bird
Re: Fj40 Handbrake
klompy wrote:Looking at pics,does'nt look like theres any handbrake.
yep no handbrake, Monte Carlo Calipers arent really very common in NZ if available at all although they are supplied in the kit and the brackets are welded and I dont know if thats certifiable here if your wanting to be road legal
probably better off using some callipers with handbrake levers that are readily available in NZ
- mudlva
Re: Fj40 Handbrake
theres an option of using a bj74 diff and moving the spring mounts in to suit a 40 that way hand brake cable is standard and the drums etc are all standard
plenty of parts around as well and it you got a semi floater diff peolpe are jusrt about giving them away
piss easy moving the mounts as well as long as you cen access a welder
just thought i would throw that idea out there
- Sadam_Husain
- Angry bird
Re: Fj40 Handbrake
mid 80's subaru leone front callipers were always one of many common conversions for rear discs, there concidered pretty old and harder to find these days but every time I go up to pick a part looking for something I always seem to end up coming home with another spare set of callipers, they used to charge 13 bucks each for them but they have gone up to $15.75 each now
they are a large single piston calliper with a simular fluid displacement to the drum brake wheel cylinders so theres no mucking around with swapping out master cylinders, its pretty hard to get full pad contact on the rotors, my 40 series has full contact but my 70 series pads hang over by 2-3mm, they usually let you get away with chamfering the edge of the pads if your certifying them, with a vented rotor I dont think you'd ever end up with the 2 pads coming in contact anyway. If the pads dont have full contact on the rotor as the pads wear down if they wear far enough and the edges of the two pads end up touching you have no clamping on the rotor and no more brakes. A pretty simple conversion, theres quite a few variations of brackets around, they work well and both my handbrakes hold real strong
Re: Fj40 Handbrake
Briaan Howat has the brackets for those i think
Re: Fj40 Handbrake
What rotors would you use sadam?
- Sausage Shack
Re: Fj40 Handbrake
Ive got the brakets here for the subaru calipers, Ive always used the early solid front hilux rotors but you can use the vented cruiser rotors.
Re: Fj40 Handbrake
Awesome cheers guys
