Prado rear trailing arm bush's
oldblue
Post by oldblue »
Any one brought them at a good price? KZJ71 or 78 #48702-60060
IcedJohnno
Trailer Trash
Re: Prado rear trailing arm bush's
Post by IcedJohnno »
I ended up using GQ Safari ones.
See my thread here; http://www.offroadexpress.co.nz/Forums/ ... 13&t=27718
Part number was; Bush-Comp Rod 54560-01J00
IcedJohnno
Trailer Trash
Here are the factory Nissan bushes that I used.
Don't buy the elcheapo ones like you can get from SAS.
This is what they look like after one very easy years use.
About to press outer out
divebrent
Post by divebrent »
Just brought some from miparts.com Much cheaper than anything local $5USD each and only took 4 days to arrive from Shanghai. Shipping was $40usd but even so it's still considerably cheaper than sourcing locally. Only problem was than only 3 of the bushes that arrived were the correct ones and one was mislabled. Have been onto their support desk and they're refunding me the money for the incorrect parts so happy enough with that. Quality looks ok but don't expect them to last too long. So ended up getting the nissan one from the local dealer much to his amusement.
Around $80each vs the $200 each toyota wanted....
1993 TOYOTA KZJ78 3.0 1KZ-TE
kbushnz
Post by kbushnz »
Must remember this one as I have noticed my Mount shop Nissan ones in the rear are starting to tear out...
suzolla
Post by suzolla »
Hi,
Have just got some Genuine Toyota suspension bush's.
Got some 48702-60050 which are listed as 80 series front arm bush's. Can do these for $55 each incl post
Also some 48702-60060 which are listed as rear arm bush's for post 1990 KZJ's and LJ's Can do these for $65 each incl post
They appear to be the same except the 80 Series front ones have 2 small holes in the rubber on each side.
Much cheaper than the $150 to $200 each I was quoted by Toyota.
Not sure why the 80 Series are $10 cheaper.
Only got 8 of each to see if there is any interest.
Tim
Smurf
Post by Smurf »
Yep, keen on a price
suzolla
Post by suzolla »
Hi,
Have added a couple of photos and prices.
PM me if interested.
Tim
Smurf
Post by Smurf »
Just to bring an old post back up.
Can anyone confirm that the front leading arm bushes in an LJ Prado are the same as the rear ones? So the Nissan ones will also fit?
Return to “Toyota”
