SimonnomiS wrote:Also can someone give me some tips on steel wheels? Last time I used 0 offset but I see there are also ones with -20? Is the any issues with running these eg rubbing ? I realize I will probably have to add flares to cover treads. Any help would be great
Hey man, I think -20 will bring the tyre in from a zero offset. If the zero's fitted the -20 should fit as well.
Edit: got it around the wrong way, as you were.
