Outter CV boots
For all Isuzu related topics
long
Outter CV boots
Post by long »
Hi Guys ive gotta replace both outer CV boots is there any thing i should look out for when pulling off the front hubs.
Or any tricks i should know b4 attempting to do it ?
sprey
Re: Outter CV boots
Post by sprey »
a friend used this guide when doing his it seemed to help.
Code: Select all
http://www.4x4wire.com/isuzu/tech/CVboots/
Suza
Re: Outter CV boots
Post by Suza »
Pop the top ball joint off and life gets really easy
:wink:
mud_slinger
Re: Outter CV boots
Post by mud_slinger »
remove the whole half shaft its easier. pull the whole hub off makes life easier. while the hub is off check the bottom ball joint cos to replace it the hub has to come off anyways
needs more curry
0272593533
george.ene
Re: Outter CV boots
Post by george.ene »
Have a look at youtube. The guy goes to take a whole side off (tie rod, locker, cv, brakes).
http://www.youtube.com/watch?v=k5xykfZJ ... sults_main
I've just replaced it in mine. if you have issues with your lockers let me know.
My Auto/DIY Blog:
http://www.georgeene.com
FORGE1
Re: Outter CV boots
Post by FORGE1 »
Suza wrote:Pop the top ball joint off and life gets really easy
:wink:
x2 :D
Return to “Isuzu”
