Steering shaft splines.
HLXCRS
Post by HLXCRS »
Hello, have a 96 solid axle hilux and am after a new steering shaft to go from the joint under the steering column to the steering box. Toyota want big money so wondering can anyone in the know tell me if any other toyota model has the same shaft/similar shaft with the same splines ? Doesn't matter if its longer as long as it doesn't have that wide flex thing on the end.
Cheers Chris.
What is goin' on ?
nstacey
Re: Steering shaft splines.
Post by nstacey »
Toyota surf or four runner has same spline count but I think shaft is shorter. I used the universal off one with the shaft of my 85 solid axle lux when the old universal broke
85 Hilux single cab
02 Grand Vitara
lexlux
Post by lexlux »
there all the same hilux & crusier , the best one to get is one of a 70 / prado / bundera , there telescopic no mucking around with the length .
HLXCRS
Post by HLXCRS »
Thanks for the help peoples,
Cheers Chris.
What is goin' on ?
vvilly
Post by vvilly »
hey all im looking to find a splined steering shaft UJ to join the 185 column to the 78 prado steering shaft
both ends are the same spline count
like this
thanks
Jase
vvilly
Post by vvilly »
Bump
SMOKEY
Post by SMOKEY »
Jase ----- just my sense of humour :? , I have a spare half inch drive UJ out of a socket set you can have :oops: , just weld it in ,
SHE'LL BE RIGHT.
FITZY.
vvilly
Post by vvilly »
Well brother It's the most sensible reply if had so far lol
vvilly
Post by vvilly »
bump
daynehrn
Post by daynehrn »
My old man does a lot of custom steering shafts, axles etc at work, if you can't find a standard one that will work I could get him to give you an idea of price to make one to suit.
Return to “Toyota”
