ln106 were to buy a high steer kit ???
brakes-shocks-lockers-etc
RNOVAU
Stropper
Post by RNOVAU »
also if anyone has done a diff fwd i would like to know if theres any tips ???
niblik
Re: ln106 were to buy a high steer kit ???
Post by niblik »
http://www.offroadexpress.co.nz/Forums/ ... 64&t=27836
sharp to deal with and a good bugger to boot.....
tomsoffroad
Flopsie
Post by tomsoffroad »
Yip Tim (Suzolla) is a good bugger to deal with and the arms he sells always fly through crack testing which you'll need to do to get the high steer certed :wink:
muddyhilux
Post by muddyhilux »
tomsoffroad wrote:Yip Tim (Suzolla) is a good bugger to deal with and the arms he sells always fly through crack testing which you'll need to do to get the high steer certed :wink:
since when??another cost to add to the mix :roll:
suzolla
Post by suzolla »
Hi Tom,
Is the crack testing required by your certifier, how much is it costing to get that done.
Bit surprised it is required as it is a one piece forging.
I may be able to get them done reasonably cheaply before i send them out.
Has anyone else been required to hve theirs tested.
Tim
J_Dub
Post by J_Dub »
My certifier said not required for same reason as you stated tim.
