convert surf 87 rear leafs to springs
brakes-shocks-lockers-etc
mudlux7
Post by mudlux7 »
hay i dnt know alot about llift kits or anything but i wanted a 4inch lift kit put on my surf but i want to change from rear leaf springs to coils but i dont know how or were to buy a kit and was wondering if some one could give a link..or just point me in the right direction and what is involved in a 4inch lift kit is it hard to do?? :D
Lynx
Re: convert surf 87 rear leafs to springs
Post by Lynx »
Its easy....
rangimotors
Post by rangimotors »
4 inchs in the rear with 1.5 inchs in the front (assuming you still have torsions) :?
mudlux7
Post by mudlux7 »
yeah still have torsions..so do the coil springs just fit rite in??dont know much lol :lol:
mudlux7
Post by mudlux7 »
but y do u only want 1.5 in the front wudnt u want 4 inches all the way round?? cus i want to raise it so i have heaps of clearanc and put big muddys on
Lynx
Post by Lynx »
What rangimotors is saying is, you cant get anymore lift that 1.5inches from your current front end... Do a site search and all will be revealed.
Cheers Daniel
mudlux7
Post by mudlux7 »
ohh so ill have to change torsion bars??
Lynx
Post by Lynx »
ideally youd want to convert to a soild front end.
mudlux7
Post by mudlux7 »
sorry 4 my stupidness lol..but what would that involve.
Lynx
Post by Lynx »
Money, and quite a bit of it, have a search around dude, its been done to death around here.
Cheers Daniel
there arent any kits mate, it has to be frabricated, spring mounts, arms, panard etc, the arms all need to at the right angles and the right proportional length and in the right planes, theres quite a bit that goes into it and the rear is the easy end :D
Smurf
Post by Smurf »
As you said in your first post, you are new to this so, ...
Why do you want to lift it that much?
You say you want to fit big muddies, how big?
I fitted 33 inch tyres to my old 1988 Surf with only 50mm spring lift and 50mm bodylift
Why change the rear from leaf to coil?
What are you intending to use the vehicle for after its lifted?
Would a different vehicle (one with a solid axle and leaf/coil sprung front end) be more suitable?
If its for looks forget about springs and do a body lift, still requires cert though.
An old IFS Surf is a good cheap 4wd, good to learn in but you can only mod them so far. They do break if you try to go too hard/far in them.
mudlux7
Post by mudlux7 »
nah ive had a few surfs and done a fair bit of 4x4 but ive never raised myn be4 always had 31 i want 33...so its quite expensive??
mudlux7
Post by mudlux7 »
would a 2inch be alot better and less hassel??
niblik
Post by niblik »
you might not have had much experience in fabbin stuffs dude but what about drivin your current rig, offroad, as is? if its a 'nay', i suggest you spend a decent amount of seat time and learn about performance characteristics and go from there.. friend of mine has an ifs surf and goes some decent places, just with a little lift and 33's.... still handles mint onroad etc..
dont throw money at it half informed dude.. it'll hurt ya pocket and possibly not get ya any better off...
p.s, dont be afraid to use full words and not text speak.. its a forum pet peeve for some. :wink:
just noticed ya 2" lift comment, yeah dude, do that and possibly mods guards slightly too.... :D
mudlux7
Post by mudlux7 »
yeah well that might be a idear...so if i were to just lift it 2inch wouldi still have to do all the fabbing??? would it be alot cheaper..beacuse i also got told about these nylon blocks..soo you put them as spacers or something dose that work in the same way or is it a realy bad idear??
Smurf
Post by Smurf »
You can fit 33s relatively cheaply, but you'll start breaking CVs, bending steering idlers and running out of power, Wheel travel becomes more limited if you wind up the torsion bars. You can fit an auto locker to help redude stress on the front driveline but there is only so much you can expect out of an IFS 2.4 diesel surf.
I had a ball with my IFS surf, it went a lot of places I didn't think it would but I think you need to know a vehicles capabilities/limits,
After ripping the steering box out of the chassis in my 88 IFS Surf I got hold of an 84 Solid axle Surf, same body shape as yours, modded the suspension, modded the steering, threw 35s on it, ... bigger motor...
I now have 1990 toyota Prado, Coils all round, 3 inch lift, 33s, locker....etc
My 84 Surf is more capable, but I have never got it finished and certed, shame really
Smurf
Post by Smurf »
mudlux7 wrote:yeah well that might be a idear...so if i were to just lift it 2inch wouldi still have to do all the fabbing??? would it be alot cheaper..beacuse i also got told about these nylon blocks..soo you put them as spacers or something dose that work in the same way or is it a realy bad idear??
Body lift.
Lifts the body up off the chassis, does nothing to the suspension
Used in conjunction with a small suspension lift you can fit 33s.
Lynx
Post by Lynx »
Get 2 inch raised springs, or resets, wind front torsion bars up, bingo 2 inch lift all round, fit 33's, trim guards, drive.
Seriously man, just have a search on here, its been done, its easy to do.
Smurf
Post by Smurf »
Mudlux7, where are you from? Someone local may be able to help you out
mudlux7
Post by mudlux7 »
i usto to have a 1991 2.4 td that went well i had 31 on that standerd height i think was a bit higher than my freinds one but maybe his just sagged...that dose suck that you didnt finish it tho..so u dont think a 87 will last very long i have not even done much with it yet i was going to raise it first but now not to sure...wht about if i kept it as leafs but got new ones with lift would i end up with same thing or???
mudlux7
Post by mudlux7 »
think ill just do this but im from motueka?
thanks every1 tho..
niblik
Post by niblik »
mudlux7 wrote:what about if i kept it as leafs but got new ones with lift would i end up with same thing or???
yup... good idea.. :wink:
and lol, but what does being from motueka have to do with searchin 'ORE' for info? i wanna be cheeky.. :mrgreen: :P
anyhoo, keep the 2.4 cool and it'll last, a chap i pedal with occasionally has got one that does bloody well and he has 35's..
mudlux7
Post by mudlux7 »
cus u asked if sum1 wud help...how dus he fit 35s on it??
niblik
Post by niblik »
mudlux7 wrote:cus u asked if sum1 wud help...how dus he fit 35s on it??
with a crapload of mods... stick with goin to 33's to ensure she's not gonna go pop or be a slug.. :wink:
Smurf
Post by Smurf »
mudlux7 wrote:...how dus he fit 35s on it??
He bolts them on.. ??LOL
it is achievable,
I am in Richmond if you want to someone to talk trough it with ya.
Smurf
Post by Smurf »
IFS on the left, Solid axle on the right, both on 33s
mudlux7
Post by mudlux7 »
dude loving the surfs ae...what dose the dark one lift up 2?
Smurf
Post by Smurf »
mudlux7 wrote:dude loving the surfs ae...what dose the dark one lift up 2?
IFS one had 50mm bodylift and new rear springs, front torsion bars wound up. And shocks to suit the lift.
I have a mate with the exact same things done to same model surf, if you want to see what to do. He has used longer spring shackles to lift the rear rather than new springs
mudlux7
Post by mudlux7 »
yes that would be good cheers
